slippage under heavy throttle - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
  • 1 Post By Paraquat
post #1 of 5 (permalink) Old 05-31-2019, 11:07 AM Thread Starter
Talking slippage under heavy throttle
06 C50 30k miles
while jamming on the throttle, motor revs and trq disappears.
usually between 20-40mph. mostly in 2-3rd gear.
shifting helps or backing off for a split second and back into it.
I know its not a rocket ship.
I know theres really not that much power to break traction.
wheel slippage? it doesn't swim its still straight.
clutch? ...could be under the load of trq.
I have cobra exhaust. should I buy the bully ecu? will that fix dead spots in a powerband?
anyone else hear of this kind of issue?
rabies is offline
post #2 of 5 (permalink) Old 05-31-2019, 11:15 AM
You can jam on the throttle on a C-50?
I need to talk to my mechanic.
I'm guessing your clutch is slipping.
2 Jack Russell's
bbqjoe is offline
post #3 of 5 (permalink) Old 05-31-2019, 11:22 AM Thread Starter
*spirited driving*
assuming (just bought) last owner left the 30k mile clutch for me to swap out.
easy and cheap enough.
the bike is rather slow but it is 500lbs or so
rabies is offline
post #4 of 5 (permalink) Old 05-31-2019, 11:26 AM
Your clutch is slipping. It may be as simple as doing a proper cable adjustment. (Something that most owners never do). Beyond that, it may require a clutch rebuild.
rabies (05-31-2019)
post #5 of 5 (permalink) Old 05-31-2019, 12:28 PM
If it were me, I'd pull back the black rubber sleeve over the clutch lever and check how the cable end looks.
A set of Barnett clutch plates are not terribly hard to change or expensive. If you elect to change the springs I recommend OEM springs or use 2 of the Barnett and 2 OEM.
If you search the forum there's a detailed procedure for doing the adjustment that addresses both cable ends. Most stealerships will only adjust the nut at the lever end.
Woodswoman likes this.
I have an '08 C50.
Paraquat is offline
The Following User Says Thank You to Paraquat For This Useful Post:
rabies (05-31-2019)
