Really frustrated - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 22 (permalink) Old 05-25-2019, 02:13 PM
If you have good compression, and you have spark, the only thing missing is fuel.
3 Jack Russell's
bbqjoe is offline
post #12 of 22 (permalink) Old 05-25-2019, 02:16 PM Thread Starter
But i just had the injector cleaned
Carolinasuzuki is offline
post #13 of 22 (permalink) Old 05-25-2019, 02:17 PM
I'm thinking then a broken lifter, or valve not opening.
What was going on right before this issue?
3 Jack Russell's
bbqjoe is offline
post #14 of 22 (permalink) Old 05-25-2019, 02:22 PM Thread Starter
I was riding down the road and on the way back it started acting up and I couldn't get over 35 but I just recently got started because it's been sitting in my brother-in-law's yard for a year-and-a-half
post #15 of 22 (permalink) Old 05-25-2019, 04:05 PM Thread Starter
I adjusted the idle screw and now I can actually get it up to 50 or 55 but that's in third gear and it levels off it won't let me go any faster, and the top exhaust pipe that goes to the back cylinder still ain't getting that hot do you think it's still something with the timing or am I still not getting enough fuel to the back cylinder
post #16 of 22 (permalink) Old 05-26-2019, 04:51 PM
Remove your air filter and squirt a little starting fluid through the air intake trying to keep the spray towards the bad cylinder do this while bike is running you should hear the bad cylinder start hitting, if so it's a fuel problem
gkeefer is offline
post #17 of 22 (permalink) Old 05-26-2019, 04:58 PM
Thanks for posting that.
I wanted to, but I'm a little leary when it comes to suggesting to other people to use that stuff.
3 Jack Russell's
bbqjoe is offline
post #18 of 22 (permalink) Old 05-27-2019, 09:40 AM
htlong's Avatar
I HEARD THAT the starting fluid is ok to use now that it is lubricated?
htlong is offline
post #19 of 22 (permalink) Old 05-27-2019, 10:29 AM
Capt Cruiser's Avatar
How many miles on the bike? When was the last time the valves were adjusted?
Sitting in a yard for 1-1/2 years.....any critters make their way up the pipe to build a nest near the head? Had that happen, was the front pipe though and it was plugged solid with bird seed. Had to remove the pipe to clean it.
Capt Cruiser is online now
post #20 of 22 (permalink) Old 05-28-2019, 12:17 AM
You DO have good blue consistent spark to both plugs correct?
Spitting any raw fuel out of the cold pipe?
If you can find or borrow a compression tester, that would be a good thing to confirm...
xjfish is offline
