2003 suzuki c50 has a ticking noise - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 4 (permalink) Unread 04-29-2019, 11:08 PM Thread Starter
The ticking noise from back cylinder changedo oil and didn't help and it has 38xxx miles on it
Holbrooksj4 is offline
post #2 of 4 (permalink) Unread 04-29-2019, 11:10 PM Thread Starter
The ticking noise from back cylinder and has alot of hold back now changed oil and didn't help and it has 38xxx miles on it
post #3 of 4 (permalink) Unread 04-30-2019, 07:12 AM
Ticking is normal for these engines. Excessive ticking is not. It all depends on where the noise is coming from. In the upper cylinder excessive ticking usually is the result of a valve problem. In the lower motor, it is usually a loose cam chain. Neither is particularly catastrophic (yet), but needs attention. The best way to narrow it down is to use a screwdriver as a stethoscope. Put the tip of the screwdriver on several places on the motor and put the handle in your ear. Move it around until you pinpoint to source of the ticking.
post #4 of 4 (permalink) Unread 05-02-2019, 07:23 PM
Kurplop's Avatar
If you don't know if the valves have been adjusted, I would start there.
Kurplop is offline
