Longevity of rear brake pads? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 14 (permalink) Old 04-29-2019, 04:29 PM Thread Starter
Whats the service life of the rear brake shoes? Just wondering as I'm pulling the rear wheel soon to service the shaft drive. The rear brakes will lock the wheel with enough force so their power seems ok. Just wondering the typical mileage you can get out of a set before replacing.
EazyDyz is offline
post #2 of 14 (permalink) Old 04-29-2019, 06:23 PM
dowxxpa's Avatar
I have 30K mils on my original rear shoes, checked them last fall and they were still good. I wonder what other owners will report.
2002 Suzuki Savage (sold)
2005 Suzuki C50T, DJ drive, Mustang seats, Brakeaway throttle lock, STS turn signal system
SW Ohio
dowxxpa is offline
post #3 of 14 (permalink) Old 04-29-2019, 08:08 PM
Gene's Avatar
Most riders will NEVER wear out the rear brakes...
The service book doesn’t provide a minimum lining thickness.
Instead they have a ‘wear indicator’ just above the brake cam lever that the brake rod attaches to.
Go through a proper rear brake adjustment according to the manual at this link and observe the indicator. That will tell you the condition.
If you are like me and want a ‘minimum lining thickness’ that you can measure - industry standard would be approximately 1/16”
Also read and know WHEN to adjust your rear brake at the link below. That will save you lots of consternation in the future. It is also a big safety issue..
Page 16 here>>>>>. http://www.jaycepatterson.com/Jayce/...dica_16-38.pdf
Page 7 here>>>>>>. http://www.jaycepatterson.com/Jayce/...te_211-230.pdf
And this link for WHEN TO ADJUST.... https://www.volusiariders.com/58-mot...otorcycle.html
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
The Following User Says Thank You to Gene For This Useful Post:
EazyDyz (04-30-2019)
post #4 of 14 (permalink) Old 04-30-2019, 07:19 AM
Like Gene said, there is no published service interval for the rear brake shoes. Truth be told, most people never adjust their brake tension, so they really don't get much wear, if any. I have helped some riders in the past who NEVER used their rear brake to slow at all... If you keep it adjusted and you use your rear brake to modulate your speed (dirt bikers know the trick) then it is reasonable to assume you could need replacement shoes in as little as 20k miles. The lining is organic, so it is not very durable and it tends to fade if overheated (such as riding down the Blue Ridge Parkway 2 up). I think I swapped mine out for EBC sintered shoes around 30k miles.
post #5 of 14 (permalink) Old 04-30-2019, 08:19 AM
10-64's Avatar
Traded the bike with original brakes with 43,000 kms on them
(BTW, In "Dog Beers", I've only had "2"!)
2019 Harley Davidson FLHX Street Glide
2015 Harley Davidson XG750 (Sold)
2010 Suzuki Boulevard C50T (Traded on FLHX)
2007 Kawasaki 250 KLS (Traded on C50T)
10-64 is offline
post #6 of 14 (permalink) Old 04-30-2019, 10:05 AM
How about the rear drum? Any info on the lifespan?
FireManC50 is online now
post #7 of 14 (permalink) Old 04-30-2019, 10:30 AM
Gene's Avatar
With the rear brake lining being the sacrificial material.... and the shielding of the drum assembly from road dirt- the drum will outlast the bike - unless the drum is damages by overheating.... there is a service limit on the drum diameter - that is unlikely to ever be reached under our riding and ownership conditions.
Now if the bike has over 100k miles that might be a service inspection consideration....
In comparison, Automotive drum brakes have a general life expectancy of 2 sets of brake shoes under the riding conditions that we experience. There is no reason to expect different for these bikes.
Seeing as we will be changing rear tires much more often than anything else on this bike - except for oil and filters.... it is easy to check the lining thickness and the drum edge for any lip development due to wear.
Brake wear has never been an issue -whereas brake fade can be a concern under aggressive riding conditions - and metallic pads and shoes will help with that.
The down side of metallic linings is accelerated rotor and drum wear - but you still will find they will outlive your ownership for the next owner to worry about ..
IF you are now the ‘NEXT OWNER’, THEN you will want to do an inspection so you can defer the worry about it to —- the next owner....
CYFHMN member ---
Gene is offline
post #8 of 14 (permalink) Old 04-30-2019, 12:21 PM
Thank you for a thorough response! How does one detect overheating of the drum?
post #9 of 14 (permalink) Old 04-30-2019, 12:53 PM
It will turn colors. Usually a lovely shade of gold, flecked with some purple where it got really hot. It will also be severely out of round if overheated as well.
post #10 of 14 (permalink) Old 04-30-2019, 12:56 PM
Gene's Avatar
You will find info on the most common reasons for overheating at this link... and how to avoid it.
Skrapiron likes this.
CYFHMN member ---
Gene is offline
