New member needs some advice! Help! - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 3Likes
post #1 of 15 (permalink) Old 03-28-2019, 05:24 PM Thread Starter
Hi everybody! Getting my bike out of winter storage and the rear brake pedal is a little sticky, whats a good quick fix for this?? Thanks in advance!
Tlparent is offline
post #2 of 15 (permalink) Old 03-28-2019, 06:49 PM
Petey2006(No)C50C's Avatar
Thumbs up
Welcome from Texas.
I'm not a mechanic but somebody'll chime in.
1960 started with a scooter.
Owned Honda (350 to Goldwing), Suzuki (2006C50C) and Victory bikes.
(2009 Victory Kingpin Low and 2013 Victory Cross Roads Limited)
Petey2006(No)C50C is offline
post #3 of 15 (permalink) Old 03-28-2019, 07:03 PM
Capt Cruiser's Avatar
Define "Sticky"
Rear brakes are all mechanical. Look at the drum in back and check the operation of the brake rod.
Capt Cruiser is offline
post #4 of 15 (permalink) Old 03-28-2019, 07:36 PM
There's a couple of pivot points that are probably sticking. Mine has always worked loose.
post #5 of 15 (permalink) Old 03-29-2019, 06:56 AM Thread Starter
When i push the pedal diwn it does not spring back up, i have to lift it with my foot, thanks!
Tlparent is offline
post #6 of 15 (permalink) Old 03-29-2019, 10:13 AM
Is the return spring broken? It's located just in front of the pedal pivot, connected to the bike frame.
buckeye4990 is offline
post #7 of 15 (permalink) Old 03-29-2019, 11:11 AM Thread Starter
I will check that! Thank you! Any advice is soo very welcome, not a mechanic so i will check everything and learn from advice
Tlparent is offline
post #8 of 15 (permalink) Old 03-29-2019, 11:33 AM
Broken or disconnected return spring, possibly rusty/sticky pivots. Spritz a little wd-40 or similar on the pivot point under the floorboard and see if that helps.
RWhitehosue is offline
post #9 of 15 (permalink) Old 03-29-2019, 04:31 PM Thread Starter
You guys are awesome!! Best thing i did was join this forum!!
htlong likes this.
Tlparent is offline
post #10 of 15 (permalink) Old 03-29-2019, 05:11 PM
So what was the problem?
