Bad noises and a “clunk” - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 2Likes
  • 2 Post By Skrapiron
post #1 of 6 (permalink) Old 03-23-2019, 08:38 PM Thread Starter
Hey all, unfortunate this has to be my first post. 2007 Boulevard C50 all factory, 23000km on it and just passed an out of province inspection at a local shop last fall when I bought it, every single time it’s been fired up it springs to life quickly and with no issues, sounds, anything.
Went to fire it up today and it barely ran, making a heck of a racket ticking and knocking, then a modest clunk and stalled out. An attempt at re-start presents a slight clunk but no crank whatsoever. This is my first bike and completely lost as to what the possibilities may be. No strange sounds, smells, smoke, burning or anything previously. Help?
File Type: jpg 6988AFAC-4CDD-4408-AEB2-F3976838C00C_1553387921655.jpg (146.2 KB, 8 views)
Dean R Bannick is offline
post #2 of 6 (permalink) Old 03-23-2019, 09:11 PM
Gene's Avatar
Originally Posted by Dean R Bannick View Post
Hey all, unfortunate this has to be my first post. 2007 Boulevard C50 all factory, 23000km on it and just passed an out of province inspection at a local shop last fall when I bought it, every single time itís been fired up it springs to life quickly and with no issues, sounds, anything.
#1. Check the oil level.
#2. I would drain the oil into a clean pan and check for Ďdebrisí...
#3. Remove the cover nut on the left side of the engine- center of the engine side cover and attempt to turn the engine COUNTER CLOCKWISE with a socket and flex handle - donít force it if it doesnít want to turn.
All th possibilities that come to mind with what you have described are in the catastrophic category....
Connecting rod.... timing chain broken...
But that might not be....
Do you have a mechanic friend nearby?
You havenít posted your location.....
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #3 of 6 (permalink) Old 03-23-2019, 09:26 PM Thread Starter
I’m in Southeastern Alberta, Canada. Thank you for the reply and the info to start me off. Oil level is good with the bike stood upright. I will check if I can spin it freely when I get finished night shift here, unfortunately this happened moments before on my way to work. The best way I can describe it is as in the post, ran excellent previously but this time made one heck of a racket before seemingly locking up and unable to crank via starter at all. I’m mechanically inclined with vehicles, have never scraped knuckles on a bike yet though.
post #4 of 6 (permalink) Old 03-24-2019, 02:03 PM
Duffy's Avatar
Consider removing and looking at the starter..........it may have crapped the bed.
Wescalero Charter Member
Duffy is offline
post #5 of 6 (permalink) Old 04-25-2019, 06:16 AM Thread Starter
So the engine came apart and is now out of the bike, trying desperately to find a complete running replacement as it’ll be far more cost effective than replacing the parts apparently. Front piston came up and hit the front cylinder head wrecking the head and valves, breaking the piston and bits fell into the crankcase, timing chain is broken and slapped around inside. From what the mechanic best tried to describe.
post #6 of 6 (permalink) Old 04-25-2019, 07:14 AM
I am sorry for your luck. You are correct, it is cheaper to replace the engine, than to purchase the individual components to affect a repair.
The block of the C50 has remained unchanged since 2001, meaning the internal components are the same for every year. But in your case, the damage to the cylinder head and piston would necessitate a complete engine.
Any 2005 to 2009 engine will work in your bike. In 2012, Suzuki introduced a dual spark engine with O2 sensors in the exhaust. You will not be able to use on of those as your ECU is not compatible.
Your best source for an engine is going to be the internet. Most often you can find donor engines on Ebay for around $1200 US.
Good luck!
Woodswoman and Whiskey like this.
