Speedometer and digital display not working - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 6 (permalink) Old 05-12-2015, 01:40 PM Thread Starter
Hey,
New rider here with a question. Just got a 2006 C50 and its been riding great, the only issue is that the speedo and the digital display (fuel gauge, clock, odometer, trips) aren't working. The backlighting, neutral, highbeam, and signal lights on the unit all work fine. The speedo sensor on the front wheel is brand new. Supposedly when you start the bike the speedo needle is supposed to cycle and the N, F, and Temp lights should come on for ~3 seconds. This also doesnt happen.
My buddy (lots more experience than me) and I took the gauge cluster off the bike and opened up the unit (after checking the new and old sensor cables (by spinning them manually) and cleaning (electronic contact cleaner) and checking all of the wiring connection. We checked the harness where the speedo connects and determined its definitely drawing strong power and the wires seem pretty snug in there.
When we opened up the gauges however, we found that the rubber seal was not sitting right (had a big kink in it right near the top of the unit), there was dirt that had settled at the bottom of the unit inside the (should have been) sealed case, and the screws holding the curcuit board on as well as the surface of the circuit board has some visible corrosion).
Is it likely the actual gauge is the issue or could it still be a wiring issue somewhere else on the bike. I found some replacements on ebay but since you can't return electronic parts I was waiting until i was more confident that this is the issue.
Thanks,
C
cwdavisUD is offline
post #2 of 6 (permalink) Old 05-12-2015, 01:53 PM
10-64's Avatar
Welcome to the Forum, from Ontario, Canada.
Someone more knowledgeable than me on this subject will chime in here soon, with an answer!
(BTW, In "Dog Beers", I've only had "2"!)
2019 Harley Davidson FLHX Street Glide
2015 Harley Davidson XG750 (Sold)
2010 Suzuki Boulevard C50T (Traded on FLHX)
2007 Kawasaki 250 KLS (Traded on C50T)
10-64 is offline
post #3 of 6 (permalink) Old 05-12-2015, 02:04 PM
summergirl's Avatar
Check and replace the fuse that is marked signal. Don't ask why but it could be the culprit. I lost 1000 kms because of this. Finched a 6000 km ride with no speedo, and brake lights. I thought if the signals worked it wouldn't be the fuse but it was. It as also on a 2006.
2011 to ? - Burgundy 2009 starting 6 kms (1 mile)
2006 -2011 - Silver and Grey 2006 - 60,000 kms (37,500 miles)
summergirl is offline
post #4 of 6 (permalink) Old 05-12-2015, 02:06 PM Thread Starter
Yeah I had seen that in a previous post somewhere else so I replaced that fuse along with several others (happened to have an assorted box of fuses lying around) no luck unfortunately
post #5 of 6 (permalink) Old 04-09-2019, 04:57 PM
I had the same problem, I am holding a burnt fuse from the signal slot in my hand now. Going to parts store to buy a new one. Thanks!
LiveWire is offline
post #6 of 6 (permalink) Old 04-09-2019, 05:55 PM
Bike is back together, everything is working. The fuse was the problem.
LiveWire is offline
