I drove my 06 c50t down the block to my friends place and shut it off, all was great. I just replaced the clutch (Barnett) 3 days ago and have been riding a lot every day since with no issues.
I put the key in, turn to start and nothing happened. No lights, no fuel pump whine, and no starter engagement. Went through the usual, make sure its in neutral, kick stand up, so on.......
I tried a few more on/off key cycles and suddenly the spedo went all the way to the top speed and then returned to 0 and the digital readout said check. Then I tried moving the key forward very slowly and the tail light flickered at the same position every time but would not stay on when the key was full on.
First I made sure the battery was fully charged and it was, just took it off the maint. charger before I left for the 800ft. trip, hooked up to my friends charger and it was topped off in 30 sec. Multi confirmed it.
I pulled every fuse, 2 30A under seat, and all behind left rear side cover- all look good. no change.
I removed the headlight and checked all plugs. all good. no change.
I removed the tank completely and checked all FI and fuel pump connecters, all good.
made sure the FI controller is plugged in fully. all good.
I have a FI2000R on the bike- unplugged it and went back to stock. no change and no lights on the FI2000R unit when it was plugged in at key cycle.
I removed the tank again and re-attached the FI2000R and got lights at key cycle but only while the fuel pump is unplugged, as soon as I plug in the fuel pump it goes away so I unplugged it for now and went stock again..
Where is the fuel pump relay and could this be the issue?????? I don't know where to go next.
put it all back together, I have lights and gauges but I still cannot hear the fuel pump at all and the starter will not turn over.
I have always had to release the clutch from full in just about an inch to get the starter to engage at all since I got the bike.
It makes a constant and very fast clicking noise when I try to start it, then stops but still no fuel pump.
