How to Change Your Coolant - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
post #1 of 24 (permalink) Old 05-31-2013, 02:11 PM Thread Starter
Bamabrat's Avatar
I'm doing this from memory, so if anyone see's something I've missed, please let me know. I know Special Ed did a "how-to" with pics, but the links in his threads are not working (at least on my pc). Therefore, I hope this can be beneficial for a few of you.
  • Make sure your bike is cool (hasn't been driven lately)
  • Use the kickstand, not a bike lift. The angle will make the rad hose drain more easily
  • Remove the passenger and driver seats
  • Remove the fuel tank bolt
  • Disconnect the speedo housing
  • Disconnect the fuel tank wire connector and quick-connect fuel line under the fuel tank
    • I always place a rag directly below the quick connect when I disconnect it because a small amount of fuel will come out
  • Pull tank back to expose the rad cap (i just removed my tank, but it's not necessary. If you DO remove the tank, fuel will not leak out if you carry it parallel to the ground)
  • Remove the 2 chrome covers on the clutch side of the bike (directly under the toolbox, and the one to the right of that one)
  • Open the cap from the coolant res
  • Look at the black rubber hose coming from the bottom of the radiator and follow it back until it meets the water pump under the toolbox. Place a catch pan under the bike where these two meet
  • Remove the clamp and pull hose away. FYI...coolant will come out quickly, so be ready, and have a couple of shop towels just in case it gets messy
  • When it has drained completely, invert the end of the hose to drain remaining coolant (don't shake it more than twice or you're playing with it)
  • Find the smaller black plastic tube that connects with the coolant res.
  • Place container under it
  • Remove clamp and drain res (FYI...I removed my res and cleaned with CLR because there was a lot of crud in it. Only took an extra 5 mins)
  • Reconnect clamps and hoses from rad to water pump and on the coolant res
  • Use 50:50 mix of distilled water and coolant. Make sure it's OK for an aluminum radiator. I just bought a Prestone pre-mix that was OK for any radiator. If you use tap water, it will rust out the rad. Make sure to use distilled, or again, just buy pre-mixed.
  • Fill up radiator slowly with a total of 1500 ML (according to the owner's manual). When the fluid reaches the top of the radiator neck, rock the bike back and forth to release air bubbles. Continue to fill. Rock. Repeat.
  • Fill coolant res to "max" or "full" line
  • You can crank the bike and let it run, which will also release some air from the radiator, and then you can add more. I filled mine, rocked, filled, etc. until I thought it was enough, then rode around and checked it the next day. I ended up adding a little bit more, but not much.
  • FYI...you can measure the amount you take out of your bike (once it's in the catch pan) to see if you were very low, or if it contained anything. My coolant was WAY past due to be cleaned. It was milky.
Good luck! Hope this helps.
Maddmike and papichuloy2k like this.
- 2005 C50 Special Edition Red w/ Ghost Flames (SOLD)
- 2001 Kaw Nomad 1500 G3 (Current Bike)
"All that is necessary for the triumph of evil is for good men to do nothing"
Bamabrat is offline
The Following 9 Users Say Thank You to Bamabrat For This Useful Post:
05C4R_M50_PTY (10-26-2013), 10-64 (06-20-2014), elad1951 (02-23-2016), hankydoodledandy (06-20-2014), HotRodSam (08-06-2015), Joneo (09-23-2015), PopPop (06-22-2014), rabies (05-31-2019), reftek (06-29-2014)
post #2 of 24 (permalink) Old 05-31-2013, 02:25 PM
dlhanshe's Avatar
Not sure if it is here, but I love this link: https://skydrive.live.com/?cid=A920C...5&sc=documents
Donn
2009 Black Cherry C50 Boulevard - Current
2009 Green/White C50 Boulevard SE - Totaled by a Tailgater
dlhanshe is offline
The Following 6 Users Say Thank You to dlhanshe For This Useful Post:
DoopM50 (05-11-2014), gabe (02-27-2019), Jamez1999 (03-05-2015), JoeTex (02-21-2016), PopPop (06-22-2014), reftek (06-29-2014)
post #3 of 24 (permalink) Old 05-31-2013, 03:25 PM
Milky usually isn't a good thing. It's usually a sign of emulsion. In cars, anyway, when you drain the crank case for an oil change and the oil looks like chocolate milk that means it's time to do a headgasket. It's water crossing into the oil.
Hopefully not the case.
I have an '08 C50.
Paraquat is offline
The Following User Says Thank You to Paraquat For This Useful Post:
PopPop (06-22-2014)
post #4 of 24 (permalink) Old 06-01-2013, 01:18 PM Thread Starter
Bamabrat's Avatar
It was actually crud built up in the coolant res. The rad coolant was fine, but thank you. It's been over 1,000 miles since, and no issues.
Sent from my PG06100
Bamabrat is offline
post #5 of 24 (permalink) Old 06-01-2013, 01:20 PM Thread Starter
Bamabrat's Avatar
Thank you, great link and info. I didn't see anything for changing coolant
Bamabrat is offline
post #6 of 24 (permalink) Old 06-01-2013, 06:46 PM
Saving for future reference
meshikanbuddha is offline
post #7 of 24 (permalink) Old 08-09-2013, 01:52 PM
+1. Plan on doing this today. Thanks for the step by step walkthrough!
2009 C50T Black/Grey
Cee Bailey's Shield/Stock Mounting Hardware, "Honest Abe" Mod, "BB Drive" - Modified VS1400 drive, Mustang Wide Touring 2-piece seat, MC Enterprises Highway Bars, Metzler ME 880 Tires, GBushing
Charles_T is offline
post #8 of 24 (permalink) Old 10-26-2013, 05:42 PM
05C4R_M50_PTY's Avatar
I did the change yesterday following these directions.
To everybody enjoying a C/M50, save yourselves some $$ and do this. It is eeeezy!
Oscar P.
'06 Suzuki M50 "Suzi Blue"
'07 Hofai HF150 "La Negrita" (You are free to ask 'bout her ) [traded]
05C4R_M50_PTY is offline
post #9 of 24 (permalink) Old 05-11-2014, 05:38 AM
DoopM50's Avatar
Smile
WOW! This is amazing.. Thank you very much for this.. Downloading and saving files in an M50 folder I made. This is awesome.
If at first you don't succeed, keep sucking until you do succeed.
DoopM50 is offline
post #10 of 24 (permalink) Old 06-20-2014, 04:42 PM
hankydoodledandy's Avatar
Great post, just as the service manual recommends!
Useful link:
My Files
'09 C50, lives in Manitoba for the summer, but is a snowbird...this year, Orlando!
'12 Victory Vision aka Jimi...at home, waiting for spring...
hankydoodledandy is offline
