C50T will not hold a charge? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 17 (permalink) Old 09-04-2012, 08:58 PM Thread Starter
Post C50T will not hold a charge?
I have a 2008 C50T. I have installed many electrical accessories... fork lights, a radio, LED lights, horn, second set of rear lights, turn/brake/running light module, and the last was driving lights. All of the accessories have their own relay installed into the circuit. My problem is, the bike does not hold a charge. I purchased a new battery, and the same thing. I leave the bike on a tender when not riding it. My bike only seems to be putting out 12.3 volts now when running, even at high idle. This problem did not appear until I added the driving lights and relay. Is this a voltage regulator problem? I am not that familiar with the charging system on a bike. Any suggestions? Any help would be appreciated. Thanks.
KCStreet is offline
post #2 of 17 (permalink) Old 09-04-2012, 09:56 PM
Dragonwingedvolusia's Avatar
Sounds like yah got a good amount of stuff on the bike. I think there was mention here of a regulator issue and service bulletin on here keep lookin around i think someone will either chime in here or will show ya where the thread is. But yes, its most likely an issue with yer charging system.
Chrome dont get yah home but it sure looks good while pushing it.
Dragonwingedvolusia is offline
post #3 of 17 (permalink) Old 09-04-2012, 10:01 PM
BearBait's Avatar
Could be that you have so much electric draw that the charging system cannot run it and charge the battery at the same time. Add up your draw in amps and wait for someone smarter than me to tell you what the available charging/running amps are for your ride.
BearBait
'16 Can-Am Spyder F3-T (Triple Black)
BearBait is online now
post #4 of 17 (permalink) Old 09-04-2012, 10:25 PM
cza888's Avatar
Could also try a process of elimination. Disconnect the driving lights circuit, start the bike and check the charge rate.
___________________________________________
2014 Suzuki GSX-R750 Current
2014 Yamaha FZ-09 (sold)
2012 Suzuki C50T 2012-2014
2009 Suzuki M50 2009-2014
2007 Honda Shadow Spirit 2007-2012
2002 Honda CB919 2002-2012
cza888 is offline
post #5 of 17 (permalink) Old 09-05-2012, 12:10 AM Thread Starter
I did that. Just unplugged the lights and the meter is reading 13.4 volts and >14 volts at fast idle. I can't believe the bike can't handle two sets of driving lights.
KCStreet is offline
post #6 of 17 (permalink) Old 09-05-2012, 01:41 AM
cza888's Avatar
Tis the nature of da beast
cza888 is offline
post #7 of 17 (permalink) Old 09-05-2012, 12:57 PM
Yeah, bikes are kinda weak in the electrical area if yah ask me. But at least it wasnt the regulator and all which is good. I forgot the old addage of Keep It Simple Stupid, when looking for the process of elimination and all. Jumped straight to it. Shame on me. Just get LED driving lights
post #8 of 17 (permalink) Old 09-05-2012, 02:24 PM
No, it is quite normal..... People think that they can add any ol' electrical accessory to the bike. But they never check to see what the charging system produces or what the bike can handle before hand. They usually learn the hard way, as you did. The C50 is a great bike, but there's a reason it doesn't come from the factory with all those electrical farkles.....
So, you much choose. But choose wisely!
post #9 of 17 (permalink) Old 09-05-2012, 02:45 PM
cza888's Avatar
Generator no-load performance:
"More than 70 V at 5000r/min (When engine is cold)", as per the Suzuki Factory Service Manual covering models years 2005-2011.
cza888 is offline
post #10 of 17 (permalink) Old 09-05-2012, 03:49 PM
captain41856's Avatar
Has your bike received the new Regulator that Suzuki recalled a few years ago? The recall was due to a charging issue. I think there is some info on it somewhere here.
Dealer was replacing at no charge.
Bill
2008 C50T
Red over White
captain41856 is offline
The Following User Says Thank You to captain41856 For This Useful Post:
KCStreet (09-05-2012)
