Black smoke - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 6 (permalink) Old 08-05-2012, 03:18 PM Thread Starter
dsmitty's Avatar
Black smoke
Looking for some feedback
2009 C50 with GMan Stealth intake, Cobra FI2000 controller and Cobra Streetrod Slashdowns pipes. Bought in May 2011 with zero miles and have put 6500 on it so far. Pot settings are at Cobra recommendation of 3-4-4 and have been running the setup for about a year with no issues.
After a ride yesterday, a buddy told me that I was blowing black smoke whenever I accelerated - even on the freeway. He's never seen that from my bike before. The only changes are that I switched to synthetic oil at the last change (800 miles ago) and last month I ran some sea foam through because I was noticing it took a few more turns on the starter for the bike to start. Have run through several tanks of gas since then - bike kicks over fine.
First thought is running rich, but I haven't changed the pot settings. Getting close to needing a valve adjustment - could that be it?
Oh - and I've noticed that the fan doesn't kick in anymore. Not getting an idiot light and the radiator fluid level is OK. Weather has been mild, maybe that's it.
Any input would be appreciated. Thanks
2009 C50 (3/2011 - 3/2014)
2007 Street Glide (2/2014 -)
San Jose, Ca
dsmitty is offline
post #2 of 6 (permalink) Old 08-05-2012, 03:51 PM
Black smoke= mixture issue
Blue smoke= oil in the combustion chamber
White smoke= water in the combustion chamber
Your black smoke is caused by too much fuel in the combustion chamber, the extra being released out the tailpipe. This can be caused by two thing: too much fuel, or too little air. Likely causes are (in order of how likely it is): a dirty air filter, the controller being set too rich (it may have been doing it the whole time but no one told you before), a vacuum leak, dirty/ sticking fuel injector, failing fuel pressure regulator, or a bad sensor giving bad info to the ECM.
Check your air filter, clean or replace as needed. Check for leaks/ cracked/ loose hoses in the intake system and engine breather system. If both are fine, dump some fuel injector cleaner into the tank. If none of these work, play with the controller settings. If the bike otherwise runs fine and is not throwing any codes, then the chances of it being something other than minor are, well, minor.
DrBob is offline
The Following User Says Thank You to DrBob For This Useful Post:
dsmitty (08-05-2012)
post #3 of 6 (permalink) Old 08-05-2012, 03:55 PM
Bullsco's Avatar
I'm not too familiar with the fuel processor however, when I switched to full syth from conventional oil my fan didn't come on again until 3 years later when I was idling in summer traffic congested by construction. There will be those who disagree but it was and is my belief the synth oil is that much more efficient at lubricating and removing heat it helps keep the operating temp that much lower.
May I also offer, confirm your fuel settings, adjust your valves and see how things progress.
06 C50, Royal Purple full synth, K&N filter, 105000 kms (65 600 mi), NC shield & bags. MC sissy bar, pillion seat levelled, rear peg swap, reversed saddlebag mounts.
"Live, don't just exist, learn from your mistakes and those of others, don't just go through the motions of life for it's too short and precious. Everything you do, embrace it, live it to the fullest extent." ... anonymous
Bullsco is offline
The Following User Says Thank You to Bullsco For This Useful Post:
post #4 of 6 (permalink) Old 08-05-2012, 05:24 PM
MoDZuKi's Avatar
My 06 M50 was running very rich on the highway.. On my Bully- I was advised to set the "trasition part throttle" a little higher (comes on later) I was finding that the bike while in cruise was thinking it was in part throttle (accellerate) mode (not full throttle- But accellerate). Of course not good while cruising.
I set the stage to delay coming in and that has vastly improved the sucking gas syndrome.
I do not know the processor you have but see if there's a setting similar and give it a try.
Cheers
BTW I have VH Cruzers, Gman intake (K&N) and Bully processor , The DJ drive made the transition worse as throttle needs to be more during higher speed cruise
MoDZuKi is offline
The Following User Says Thank You to MoDZuKi For This Useful Post:
post #5 of 6 (permalink) Old 08-05-2012, 06:42 PM
ive read that synthitic will run cooler keeping motor temps down as much as 60 degrees
Briany is offline
The Following User Says Thank You to Briany For This Useful Post:
post #6 of 6 (permalink) Old 08-06-2012, 01:18 PM
Thunderhoof's Avatar
60 degrees!?
"Black Stallion"
2005 Vulcan 1600 (current)
2001 Volusia (current)
1985 Gold Wing (sold)
1985 Magna (sold)
Thunderhoof is offline
