Totally dead - no power - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 45 (permalink) Old 05-16-2011, 08:43 PM Thread Starter
C50nVA's Avatar
I'm sitting in a little traffic on the way to work last week getting ready to merge into the GW Parkway and as soon as I start to take off the bike dies. I figured I just stalled it as I began to move but when I hit the button to fire it back up, nothing. Did a fast check on the kill switch, etc. and went to put it in neutral to try again and realized I had no neutral light, or any other light.
After pushing it to the side of the road to take a better look it became very apparent I had a total and complete absence of electricity flowing anywhere.
Started checking fuses, then wiring connectors and everything else I could think of.
Fast forward 3 hours with no bathroom, no water and the patience meter pushing zero I figured I had been bitten by the infamous ignition switch bug. Of course, no security Torx bit to do it the right way, so I ripped the wires out the back of the switch to hot wire it. Yea...guess what else didn't work.
15 hours later I get it trailered and back home.
I took the ignition switch apart and the insides could pass as new. Everything I've checked looks great, but the bike acts like there's no battery in it.
Looking at the wiring diagram, it seems like the only thing left I can't really check is the ECM. I didn't think that could cause a complete power failure but I'm running out of options.
So, does this ring a bell of familiarity with anyone? Can the ECM cause these symptoms or am I overlooking something?
Thanks for any and all advice and/or suggestions.
Nelson
2005 C50 Limited
If you see a turtle sitting on a fencepost, you can be sure he had help getting there!
C50nVA is offline
post #2 of 45 (permalink) Old 05-16-2011, 08:53 PM
MACDBF's Avatar
I had a simular problem end of last year. Ended up being my battery. Total loss of power, no lights, no nothing. My service guy said the battery was toast, figured the plates let go inside. I couldn't charge it or anything. Just saying it might be the battery, it worked perfect the day before too.. Hope you get it fixed,
Mac
Joe
2005 C50/2005 HD Ultra Classic.
MACDBF is offline
post #3 of 45 (permalink) Old 05-16-2011, 09:19 PM
rvcycleguy's Avatar
Lost complete circuit or ground to the battery somewhere. Had a similar loss of voltage to everything last year and it was the connection at one of the battery posts. Fastner nut on the battery or lug vibrated or fell off (down) and cable was sitting on post by gravity. Went to take off and the cable moved away from the lug and all went dead. Took a while to sort it out.
2006 HD Road King FLCRCI
2010-Guanajuato, Mexico
89A-Sedona, Grand Canyon NP
CO Rocky Mtn. NP
2013/2014 Scenic 30A FL
2014/2015- Big Bend
2017- Santa Fe, Taos
rvcycleguy is offline
post #4 of 45 (permalink) Old 05-16-2011, 09:37 PM
funbikerchick's Avatar
Check the battery. Bike batteries often give no warning before they die.
2014 Heritage Softail Classic (FLSTC)
Why sit and steer when you can lean and soar?!
Semper Fi
Use of the word parsimonious is anything but!
funbikerchick is offline
post #5 of 45 (permalink) Old 05-16-2011, 09:46 PM
What the others said. Pull and check the 30 amp fuse near the battery. Don't just look at it, but check it with a volt meter. But I do believe your battery crapped out too.
post #6 of 45 (permalink) Old 05-16-2011, 10:04 PM
FPS
FPS's Avatar
Exactly the same thing happened to me when my battery went. Everything was great and then bam.......nothing. Check your battery, if it isn't HIGHER then 12.7 volts it is dead
Originally Posted by kydragonrider
I've owned my 2006 C50T for a year now and was totally satisfied with it until I joined this site.
Originally Posted by rodie1200 View Post
It's not what you ride, but if your wife will let you ride
FPS is offline
post #7 of 45 (permalink) Old 05-16-2011, 10:19 PM
Red-C-50's Avatar
My battery just did the same thing..
Join VR Members for Trivia at...
http://www.funtrivia.com/private/main.cfm?tid=94188
B.A.D.D.
( Bikers against Dumb Drivers )
2005 red C-50 Totaled
Red-C-50 is offline
post #8 of 45 (permalink) Old 05-16-2011, 10:39 PM
Time frame to replace battery?
Reading these stories about the battery just going dead, even while riding.
Any thoughts of what time frame to change out the battery as normal maintenance instead of waiting for it to die?
Seems like once it goes, it goes, unlike a car battery which wont start the car, it sounds like a bike battery can die, even while riding?
What would you all say would be a safe time in years to change it?
Any thoughts? 3, 4, 5 years?
2014 Road King (current)
08 V-Star 1300 Tourer
07 Boulevard C50
Our Future... http://www.usdebtclock.org/
alarmguy is offline
post #9 of 45 (permalink) Old 05-16-2011, 10:46 PM Thread Starter
C50nVA's Avatar
I just had a thought...maybe it's the battery!
It IS 13 months old and just slightly out of warranty, so it makes perfect sense. (I think they build them that way.) There were no signs of any problems with it and I never had one just "die" like that so in all honesty I didn't really factor it in or give it a good check.
I'll pull it tomorrow afternoon and get it checked properly to make sure it's either good or bad and post results.
I really appreciate the advice everyone - this is why I came here before spending any real money or wasting any more time chasing my tail!
2005 C50 Limited
C50nVA is offline
post #10 of 45 (permalink) Old 05-16-2011, 11:00 PM
With batteries they are kinda funky in motorcycles. During the winter I have a battery tender on it at all times to make sure that the cold doesnt harm it. Ofcourse the tender isnt charging it the whole time but it does the job I have had the one in the motorcycle for 2 years now and still running strong. The first battery I had died within the first year after the winter that i didnt have a tender on it.
I would also check the fuses, the one that runs the kick stand switch, fuel pump, and all electrical on the speedo. If this is blown there will be no power and no starting.
CustomC50 is offline
The Following User Says Thank You to CustomC50 For This Useful Post:
RobL (05-18-2011)
