Shifting issues - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 6 (permalink) Old 03-13-2011, 08:46 PM Thread Starter
Shifting issues
I have a 99 1400 Intruder that rides great other than a sticky shifter from time to time.
The issue is in 1st and 2nd gear. When I shift to first or second the shifter stays in the down position and does not rebound. This is not a huge problem in first as you have to up shift regardless. But if I shift to second and then need to shift to first it is very annoying to have to up shift before I can downshift into first.
Any thoughts?
dmoney2023 is offline
post #2 of 6 (permalink) Old 03-13-2011, 08:51 PM
Pull the linkage apart and grease it.
Wood Welder is offline
post #3 of 6 (permalink) Old 03-13-2011, 08:55 PM Thread Starter
Ok.
post #4 of 6 (permalink) Old 04-06-2011, 03:15 PM
Don't use heavy grease. Lockease with graphite works well.
What's black and blue white and redd all over? An '03 Vol, black. '06 Kaw Concours, blue, '08 Boulevard, red and white.
monkeydunk is offline
The Following User Says Thank You to monkeydunk For This Useful Post:
rayne (04-07-2011)
post #5 of 6 (permalink) Old 08-20-2019, 01:51 PM
I had the same issue on my -04 VL800. Apparently there is no bushing for it. I did take the shifter and bracket off and then cleaned up the shaft. If was rusty and had some gouges in it. I sanded it and then filed it smooth. I used spray lithium grease on it and the bike shifts like new. Thanks to all for the advice.
frankg is offline
post #6 of 6 (permalink) Old 08-20-2019, 04:25 PM
They do make a bushing for it and Gman seems to make the best.
