Oil leak from around Bolt Head - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 14 (permalink) Old 08-27-2019, 10:27 AM
JJ's Bully's Avatar
Having the same problem, same bolt since it went into the shop to put in Barnett clutch plates- also seems to be oil leaking out the top- i'm wondering if it's overfill too, have to go check the levels ( with some help as always- groan) and the air filter
I am wondering if i should have had a new gasket also at the time the plates were changed. Will try this fix in the meantime- where can i get this stuff in Canada, any idea?
thanks!
-JJ
2011 c50 T ~Also a good idea for YOU to look twice, save your own life~
JJ's Bully is offline
post #12 of 14 (permalink) Old 08-27-2019, 04:18 PM
There's lots of places online that ships to Canada. The OP had his leak on the right side( as you're sitting on it. Yours seems to be on the other. If you had the clutch replaced, sounds like they used the old gasket instead of a new one. Could be they just didn't get the bolts torqued correctly.
The Following User Says Thank You to scorpion46 For This Useful Post:
JJ's Bully (08-27-2019)
post #13 of 14 (permalink) Old 08-27-2019, 09:26 PM
JJ's Bully's Avatar
thanks much. Nope the right side (sitting on the bike). i don't have a torque wrench -(yet) -can i hand tighten or go shall i go back the the shop? Have a 12 - 18 hr round trip ride coming up and want to get it looked after . TIA
-JJ
post #14 of 14 (permalink) Old 08-28-2019, 02:43 AM
If it started leaking after they had it apart, make them honor their work. Those bolts are torqued in inch- pounds and can break fairly easily.
JJ's Bully (08-28-2019)
