Diagnostic codes, FI light and stuff - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 16 (permalink) Old 11-19-2010, 11:55 PM Thread Starter
Tonight I had a really nice consistent, repeatable non-start occurence. I was able to pull the code and it was a c12, CKP Sensor not present. The manual says the sensor should read 184-276 ohms. Mine read ~2.1K ohms which is off by an order of magnitude from the manual value. This could be my problem or it could be a typo in the manual. My connector (which oddly enough is directly behind the tool kit container) was a little ratty looking so I cleaned it up somewhat. I still have a background issue that's throwing a c28,c29 code but I think that is a separate distractor. The case where the engines shuts down and won't restart I'm pretty certain involves the CKP sensor. It is one of only a couple of signals that will prevent the engine from starting even though it turns over and the fuel pump runs and all the rest.
Chatman128 is offline
post #12 of 16 (permalink) Old 11-30-2010, 02:16 PM Thread Starter
So my intermittent problem has now become mittent. My symptom was: bike starts normally when cold (this was constant throughout). Occasionally bike would die when stopped at idle. Bike would not restart until the engine totally cooled off. This past week I could not go more than 1.5-2 miles before the bike would die. The CKPS was looking more and more like the culprit and the code displayed was consistently c12, so ....
Last night I measured the CKP resistance when I got home and it was moderately normal (500 ohms vs 180-270). I rode the bike up and down my driveway until the bike successfully failed and then checked the reading again. This time it was megohms. Barring a bad solder joint connecting the cable to the sensor (not an altogether unlikely possibilty but one I'm not willing to investigate until I have an alternate part in hand) I think the offending part has been located. Got a replacement coming from fleabay. We'll see how that works out.
I hate driving to work.
post #13 of 16 (permalink) Old 01-05-2016, 07:54 AM
Tango Papa's Avatar
Pull the Speedo off the tank and check the mating of the cable plug to the speedo unit. I had this problem and that was the fix.
Tango Papa is offline
post #14 of 16 (permalink) Old 01-05-2016, 08:02 AM
Tango Papa's Avatar
I bought the Clymers repair book on-line. It does an exceptional job at listing all the codes. And, for those of you who've bought these books before, they do an exceptional job at covering all types of maintenance. I highly suggest getting this book if you're a DIY kind of repair guy. I have one for my 1978 GS750EC.
post #15 of 16 (permalink) Old 01-05-2016, 10:39 AM
FWIW: 5+ year old thread.
post #16 of 16 (permalink) Old 06-10-2019, 01:27 AM
Dg5150az's Avatar
Hello I'm new here I recently bought an 04 intruder VL 1500 and was wondering if it gives trouble codes or not can anybody please let me know
Dg5150az is offline
