HOW TO: Wiring new accessories through a RELAY - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 231 (permalink) Old 01-07-2008, 07:09 PM
summergirl's Avatar
you got that right.
summergirl is offline
post #22 of 231 (permalink) Old 01-07-2008, 08:12 PM
MScruizer's Avatar
Thanks for the post, it will help me in the future.
2006 C50C Pearl White
OEM Windshield
ISO flame grips
Debaffled
Demickeyed (twice)
Debadged
Lic plate laydown
Lowered 3"
MS Enterprise hiway bars
Lonnie's backrest
MScruizer is offline
post #23 of 231 (permalink) Old 03-08-2008, 11:19 PM
m@c's Avatar
Re: HOW TO: Wiring new accessories through a RELAY
Originally Posted by moenko
A relay is an electric switch which, when energized, will close a second, totally independent circuit. Below is a drawing I made for a simple setup of wiring two add'l driving lights. Note that the rocker switch gets its energy from the IGNITION circuit and when turned on, will close an independent circuit (in the relay between poles 87 and 30) and safely run your lights (or anything you connect) on it's own, fused(!) circuit.
ok, so why is there power from the battery and the ignition? into the relay?
if you swicth the switch off, you would still have power from the battery?
would you not?
post #24 of 231 (permalink) Old 03-08-2008, 11:26 PM
m@c's Avatar
no , no you would not
because the power from the ignition turns the relay on and allows the battery power to go to the lights
right?
post #25 of 231 (permalink) Old 03-08-2008, 11:57 PM
Umple Z's Avatar
right?
Exactly. That is why it is called a relay.. and not just a switch... it's a "smart" switch.
Umple Z is offline
post #26 of 231 (permalink) Old 03-09-2008, 08:19 AM Thread Starter
moenko's Avatar
Hehe, don't know about "smart" but it it's ingenious nonetheless. [email protected], I wish I could show you an open relay I have here at home, you would laugh at how simple of a device it is. When you send power to it from the options connector (between 85 and 86), you energize a small coil that acts as a magnet. Once the coil is energized, it "pulls" a contact down until it meets another contact and thereby closing a new circuit (between 30 and 87) straight from the battery. This new circuit can handle as much Amperage as the relay is rated for (usually 30 Amps in our applications). Depending on the wire size you use, make sure to match the in-line fuse to that wire (chart is on previous page).
Imagine that: You ask only around 3 Watts from the options connector to energize a magnet, and it will close a circuit of up to 30 Amperes (!!) for you; yet your ignition switch would never know, it's only being "tickled" by a barely noticable "ballast" of 3 Watts.
There are several styles and varieties of relays, you only need the most basic one, a so-called SPST (single pole single throw) relay with 4 posts, cost is about $5 in any auto parts store. A cheap peace of mind!
OH - lastly, if you plan on having the lights on ALL THE TIME whenever the bike is running, you can cut out the manual switch altogether. The relay will always be powered and so will your lights when you turn your key. What I don't like about that setup is that when you start your bike, you need a good amount of Amps from the battery to turn the starter - the add'l lights will take up to 10 Amps from the battery before you crank it, making this setup unattractive to me, but it will work.
Carsten
2004 BMW R1150RT (sold)
2006 Yamaha Stratoliner S (sold)
2006 Kawasaki Nomad 1600 (sold)
2005 Suzuki C50 (sold)
moenko is offline
post #27 of 231 (permalink) Old 03-14-2008, 06:11 AM
pac50t's Avatar
would you not?
Pin 85 and 86 zap the troll that lives inside the relay. Once he wakes up, he flips the switch that connects pin 30 and 87. A relay, quite simply, is just an electrically controlled switch using a low current input to control a high current output. Your starter is fed by a relay that is controlled by the start button, because all the current sucked up by the starter motor would melt that itty,bitty starter button.
Some people think that they know. But, they don't know enough to know that they don't know.
https://www.volusiariders.com/viewtopic.php?t=51362
http://www.facebook.com/album.php?ai...9&l=eeb1a3e8b5
pac50t is offline
post #28 of 231 (permalink) Old 03-14-2008, 06:43 AM
krislord's Avatar
wire
Originally Posted by big ed
And when you finish the math here's a chart to select the wire gauge:
I think the amps are a little high on that chart.
Its about the ride, not the party after!
krislord is offline
post #29 of 231 (permalink) Old 03-15-2008, 07:45 AM Thread Starter
moenko's Avatar
Re: wire
Kris, I think they are pretty accurate. Keep in mind that in low-voltage circuits more current is usually flowing than in high-voltage circuits. You can't compare this chart to your home wiring, obviously it would be totally out of whack.
Carsten
moenko is offline
post #30 of 231 (permalink) Old 03-15-2008, 11:36 AM
Hello
I am trying to "save" the ignition switch failure possibilty and am trying to use the diagram Moenko has included. Seems simple but got a quick question my spotlights only have single (positive) wire feed from the headlight bucket. They are a mechanical ground light, I have run the negative from the battery but what should I do now?
My thoughts are feding a second wire out to the spotlights and unhooking the mechanical ground in each light and basically adapting my mechanical ground to go direct to the battery?
Edit: I went ahead and ran sepearte ground wires which allowed me to follow the schematic to a "T". Also upgraded to 4411 sealed beams as well, much brighter!
Thanks for the schematic Moenko, made life a lot easier
Buttsy is offline
