How to fix your Ignition Switch - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
post #11 of 149 (permalink) Old 10-08-2007, 10:11 PM Thread Starter
harryp's Avatar
Originally Posted by 472viper
LOL, no get this, the M50 was hit so hard that the key side of the ignition switch cracked almost in two. I have another switch assembly, but as you said I will have to remove the the keyset from the cracked set and install it in the replacement so the ignition and gas cap are still keyed alike.
Viper
Once you remove the 2 little screws on the key side, there is only 4 parts.
The lock cylinder, a spring, a cylinder cover, and main cover.
Here is the cylinder...
Here is the spring inside the switch. Carefull, as it can just fall out. If you have a problem getting the cyclinder back in with the spring, put a dab of grease in the end of the cylinder. It will hold the spring for you. I used the bulb grease. The spring goes over the rod inside there that turns.
Then the 2 covers.
Hope this helps.
harryp is offline
post #12 of 149 (permalink) Old 08-06-2008, 10:24 AM
SiouxperKev's Avatar
DAMN I wish I would have seen this a while back. I ended up buying a whole new lock set (used, at least) because my ignition switch went bad out in Sturgis. Stopped me dead. I don't remember, but I don't think I had any lights or anything. Thankfully Cobra and JJ got me wired up to get me home, but I ended up buying the parts.
As for the recall, it wasnt covered on the 03's anyway.
Got to mark this for the next time it happens. Thanks for the great details.
Let's Ride!!
2003 40th Anniversary Volusia
You are only as strong as the tables you dance on, the drinks you mix and the friends you roll with.
SiouxperKev is offline
post #13 of 149 (permalink) Old 09-02-2008, 12:08 AM
Subscribed and you were right on the money. I only wished I hadn't pulled the whole switch off the bike first cause it's a ***** to get off, god only knows how long it'll me take to get it back on...LOL
C50dreamin is offline
post #14 of 149 (permalink) Old 09-02-2008, 06:57 AM
brownC50's Avatar
Many Thanks harryp for thinking of everyone else. I haven't had this problem (yet), but I'm saving this info for future reference.
"Ah Say... Ah Say... Saw an old high school classmate the other day for 1st time in years. Introduced me to his trophy wife. Guess he did not take 1st place."
2005 C50 Black... 2007 to 2015
2007 Kawasaki Vulcan 1600 ... 2015 to ?
brownC50 is offline
post #15 of 149 (permalink) Old 09-03-2008, 08:56 AM
Iginition switch
My C50 failed to start on a Sunday, 70 miles from home ,in a area that doesn't have cell phone reception. After a couple hours of checking all possibilities and pushing the starter button, the starter motor finally kicked in. I drove it home with stopping. When I got home the starter worked intermittently. I took the bike to the dealer and the problem couldn't be replicated. It worked fine. Several months later the starter motor was dead again...fortunately while I was at a friends house, about nine miles from the dealer. The dealer sent a truck over to pick up the bike. They found the problem the next day and replaced the ignition switch under the extended warranty. The dealer described the copper contact sticking exactly as you presented in your pictures. Nice job on documenting the fix!
Raygun is offline
post #16 of 149 (permalink) Old 09-05-2008, 07:55 AM
Peter69's Avatar
Year Bike
Is this recall only on C-50's or Volusia's too?
2003 Suzuki Volusia VL800-61,500 Miles and still going-(01/04 - 04/12) SOLD!!
2004 Suzuki Marauder VZ1600-25,500 Miles-(10/07 - 5.16) Traded!!!
2011 Victory Cross Country-69,500 Miles-(07/11 - Present)
2016 Indian Chieftain- 13,500 Miles-(05/16-Present)
Peter69 is offline
post #17 of 149 (permalink) Old 09-05-2008, 12:46 PM
Its not on the 2003's as far as I know. I tried that and got nowhere so I am guessing its only the C50's. Also, I believe the recall is only on a wiring issue (may include a harness) but its not for the switch.
Let's Ride!!
post #18 of 149 (permalink) Old 09-05-2008, 01:21 PM
Recall is only for the way the wiring harness is ran and not for the actual switch...
post #19 of 149 (permalink) Old 09-19-2008, 12:11 PM
azryder's Avatar
Re: Iginition switch
Would your bike crank at all when you had this problem? I'm having it on my c90 and it will crank but it's getting no spark. I'm going to try cleaning the iginition switch tonight and see if it helps. everything else seems to check out.
azryder is offline
post #20 of 149 (permalink) Old 09-19-2008, 02:17 PM
Fstpicker's Avatar
When my ignition switch went out this week, nothing would happen when it turned the key on...no headlights...no dash lites...only taillight and turn signals worked.
It's in the shop now for its replacement under extended warranty coverage.
Jeff
Fstpicker is offline
