Changing headlight - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 14 (permalink) Old 08-30-2007, 07:50 PM Thread Starter
Changing headlight
I can't find my owners manual. How do you change out your headlight? I want to replace with the silverstar. I ran into a stupid moped a few weeks ago, he had no tail light at all. They should not be allowed on the highways. Luckily nobody got hurt. Hoping a brighter light will help. Is there somewhere you can download a owners manual?
ncvolusia is offline
post #2 of 14 (permalink) Old 08-30-2007, 08:56 PM
Air4ceOne's Avatar
Look near the bottom on both the left and right sides. You'll see small screw on each side. Take both of them out, lift up easily on the bottom of the housing. It'll come loose and then it'll disconnect at the top as well. After that, it's simple. Just remove the rubber boot, open the snap holding in the light bulb, remove it (keep it as a spare), insert the Silverstar and reverse the process. Be careful not to touch the actual bulbs though.
Air4ceOne is offline
post #3 of 14 (permalink) Old 08-30-2007, 08:57 PM
You could try therusks.com for some how-to's.
But, to remove headlight, unscrew the chrome ring - 2 philips on the sides.
Remove the head light, disconnect the wiring, remove the bulb!
It is easy.
Reverse the steps to install.
Verify aim is correct. Don't want you getting "flashed".
No problem!
Anything else, just ask.
walpeg is offline
post #4 of 14 (permalink) Old 08-30-2007, 09:27 PM Thread Starter
thanks for the help.
post #5 of 14 (permalink) Old 08-30-2007, 10:59 PM
MrChili's Avatar
Ncvolusia, make sure the Phillips head on the screwdriver is the right size, and you may want to carefully squirt a shot of penetrating oil on the screws first. They can be a little beggar to turn and the heads strip easily.
Regards
Old too early.....Smart too late.
MrChili is offline
post #6 of 14 (permalink) Old 08-31-2007, 09:54 AM
And, the holes those two phillips screws go into is cheesy thin metal, they will strip real easy and never hold your headlight rim tight, make sure the rim hole for the screw and the hold down treaded hole inside is perfectly aligned before you screw.......I put a piece of tape to hold the screw because of that.
Mort is offline
post #7 of 14 (permalink) Old 08-31-2007, 10:23 AM
+1 on the cheesy metal. And the screws themselves are cheesy. EZ to strip. Use
a good screwdriver.
Okie is offline
post #8 of 14 (permalink) Old 08-31-2007, 11:12 AM
wiseguydave's Avatar
Any further quesions on this contact Basshole...
Some men think they are God's gift to women...not me...I think women are God's gift to ME...
My Gallery
wiseguydave is offline
post #9 of 14 (permalink) Old 08-31-2007, 11:46 AM
Okie is offline
post #10 of 14 (permalink) Old 08-31-2007, 12:07 PM
TNrookie's Avatar
Yep...Something tells me he'd have lots of, uh, input on this matter.
aka RockyStop, TNsmartass
Chairman and Co-Founder, Stebel CYFHMN Club
'02 Nomad 1500
Bikes I Miss:
'04 Volusia (Black)
'07 C50 (Red/Black)
'04 Volusia (Blue/Gray)
TNrookie is offline
