12v led - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 4 (permalink) Old 07-23-2019, 11:26 PM Thread Starter
12v led
Do I need to do anything special to run 12v led lights?
Rplummer71 is offline
post #2 of 4 (permalink) Old 07-24-2019, 08:15 AM
Are you talking accent lights or turnsignals and such?
post #3 of 4 (permalink) Old 07-24-2019, 10:33 AM
It depends what you are adding: there could be relays involved, incompatible LED bulbs, too much current load, etc.
Rule of thumb: Anything electric you add, make sure it is fused in one way or another: either tap into a fused line, or if connecting directly to battery - add an in-line fuse. Even better: add a fuse on your accessory anyway, so you don't run into melting the wiring or loosing a crucial system if the accessory misbehaves.
FireManC50 is online now
post #4 of 4 (permalink) Old 07-24-2019, 05:38 PM
If you're planning on accent lights, make sure you run them thru a relay and have an inline fuse.
If you're changing to LED turnsignals, you'll have to either add resistors or change to an LED flasher to stop the hyperflashing.
