Lowered 2" now there is a leak - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 5 (permalink) Old 05-23-2019, 08:28 AM Thread Starter
Tank 1020's Avatar
I lowered a 2002 Volusia 2" yesterday. There is an oil leak now. It looks to be coming from a seal around the drive shaft. Does the shaft need to be adjusted? Or is the seal a typical place for a leak? Thank you for the info.
Tank 1020 is offline
post #2 of 5 (permalink) Old 05-23-2019, 11:06 AM
tmunoz's Avatar
I had lowered my c50 2.5 inches and no problems with leaks of any kind. I think yours my be coincidence? I have since raised mine back after riding it like that for about a year for other reasons.
tmunoz is offline
post #3 of 5 (permalink) Old 05-23-2019, 12:05 PM Thread Starter
Tank 1020's Avatar
Thank you.
post #4 of 5 (permalink) Old 05-23-2019, 04:03 PM
Is it where the shaft goes into the rear housing? If it is, then a seal, would be all you need. If the seal is being replaced, most replace the circlip at the same time. While your at it, you should grease your drive shaft teeth since you're already there.
post #5 of 5 (permalink) Old 06-12-2019, 01:25 PM
it could be you had a the leak. but lowering exposed it.
like using synthetic oil...doesn't create leak but expose kinda theory. just thinking out loud
rabies is offline
