Ignition wire for bluetooth speakers/clock - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 2Likes
  • 2 Post By Skrapiron
post #1 of 3 (permalink) Old 05-04-2019, 09:29 AM Thread Starter
Looking for some help locating the ignition wire that I need to connect my set of bluetooth speakers to. There are three wires: Black, Red, and Green. Black to battery negative, Red to battery positive, and Green to ignition.
Any help or suggestions would be appreciated.
Dan Dickman is offline
post #2 of 3 (permalink) Old 05-04-2019, 10:04 AM
Use the switched accessory plug in the headlight bucket.
DickB and Dan Dickman like this.
Dan Dickman (05-04-2019)
post #3 of 3 (permalink) Old 05-04-2019, 01:33 PM
DickB's Avatar
Dan also needs a + battery connection to keep the clock running. I would still use the accessory connector in the headlight bucket for - and switched (ignition) power. I would tap constant (battery) power from the supply to the speedometer. My M50 wiring diagram says it is red with a black tracer, but I would check with a voltmeter. BTW both circuits are already fused, so I would not use any fuse holders that came with the Bluetooth, as they would be redundant.
2006 blue M50
2019 Honda Super Cub C125
1983 Wetbike (sold)
DickB is offline
