Valves Adjustment - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
  • 1 Post By Gene
  • 2 Post By Rob 61
  • 1 Post By Whiskey
post #1 of 6 (permalink) Old 04-24-2019, 11:14 AM Thread Starter
Valves Adjustment
Howdy all?
I have owned a C50 for a little bit over a year now. It has just a bit over 7000 miles. I have read that the 7000 miles is when I need to check valves clearance and eventually make some valves adjustments.
My question is: How complicated is it to do this maintenance task? I have never done valve clearance on a C50. I have done it on a BMW and Ural bikes. Both of these bikes have boxer engine which makes this maintenance task extremely simple and easy to perform.
I have seen a couple of videos on YouTube. However I am still not sure how easy it is to do it. I have next week off and I will have plenty of time to do it. How long should I expect it to take? I have all the necessary tools.
Thanks in advance for your invaluable input!
mouka is offline
post #2 of 6 (permalink) Old 04-24-2019, 11:39 AM
Gene's Avatar
Originally Posted by mouka View Post
Howdy all?
YES it is time to ADJUST THE VALVES.
SOME people call it checking the valves but the adjustment is very important - not just checking them.
Experience and recent experience will allow you to do the job in about 2.5 hours. For the first time adjuster allow 2-3 times that long.
Keep in mind that there are two of each of the intake and exhaust valves per cylinder. They are supposed to open and close simultaneously. If one intake has 0.004” clearance and the other right beside it has 0.005” clearance the cylinder will sound like a single valve having 0.008” clearance..... the double click will amplify the sound..... same on differences between the exhaust valves.
NOTE!!! *****In the service manual there is no - or even incorrect instruction on which way to turn the crankshaft.
******Use the socket and ratchet on the generator nut as shown to turn the crankshaft COUNTERCLOCKWISE FROM THE LEFT SIDE OF THE ENGINE..... so that the crankshaft rotates toward the front of the Bike as it comes closest to the top of the bike. If you turn the crankshaft backwards you run the risk of affecting the timing chain tensioner and timing chain lift - that is my opinion after reviewing the design and operation of those components.
Here are a couple of threads that you might find helpful to get the job done.
Also a link to the service manual - valve adjustment is under ‘periodic information’.
Read closely. And please ask the question that come to your young and fertile mind....
https://www.volusiariders.com/58-mot...-pics-vid.html
https://www.volusiariders.com/58-mot...ent-tools.html
Volusia Service Book
Rob 61 likes this.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #3 of 6 (permalink) Old 04-24-2019, 12:24 PM
This is why I like this forum and it's members so much! There is always a knowledgeable and experienced (very important) person coming forward to help!
post #4 of 6 (permalink) Old 04-24-2019, 03:44 PM
Rob 61's Avatar
And engine needs to be cold. Patience & bad words will get it done
Gene and Whiskey like this.
Robyn
Ray II, 07 C50 10/11-2/19
Ray I 04 Volusia 7/07-4/11
Rob 61 is offline
post #5 of 6 (permalink) Old 04-24-2019, 05:45 PM
Whiskey's Avatar
No kidding! I never did the valves on my Suzuki, but I've done it on my RT.
Valve one... Perfect.
Valve two... Got it.
Valve three... Almost there.
Valve four... [email protected]! Why did valve one move?
Valve one... F##k! Seriously?! Why did valve three change?
Valve three... Son of a ****! Now two changed!
Yup. Lots of patience.
Rob 61 likes this.
2005 Boulevard M50 (DOA)
2006 Boulevard C50 (retired)
2000 BMW R1100RT
2017 KTM Duke 390
Whiskey is offline
post #6 of 6 (permalink) Old 04-24-2019, 09:22 PM
Rob 61's Avatar
Robyn
Rob 61 is offline
