I got tired of valve noise. Here's what I did. - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
post #1 of 16 (permalink) Old 06-01-2018, 08:52 PM Thread Starter
After researching this issue several times, I'm was convinced there is no way to quiet the Suzuki V Twin beyond using a high grade synthetic. I've had two and the both hammered like diesels even with Mobil 1 and Amsoil. Today I got brave and decided to try an oil additive. I put 12 oz of Lucas Oil Stabilizer in the crankcase. This stuff is super sticky and clings to everything. I ran it for about 30 min afterwards and the bike does run a lot quieter. Not sure how long it will last. Just wondering if anyone else has tried this and if they've had any luck.
I lost my job at the bank the other day. A lady came to my window and asked me to check her balance so I pushed her down.
mdhyre is offline
post #2 of 16 (permalink) Old 06-01-2018, 09:20 PM
Hammered like diesels?
Do you do your own valve adjustments?
ďSociety is nothing more than people cooperating with other people they'd much rather murder.Ē
2 Jack Russell's
bbqjoe is online now
post #3 of 16 (permalink) Old 06-02-2018, 02:47 PM Thread Starter
I paid a mechanic to adjust the valves about 3,000 miles ago.
mdhyre is offline
post #4 of 16 (permalink) Old 06-02-2018, 05:39 PM
All v twins clatter a bit, its normal. if you want quiet get an IL4 with hydraulic lifters
EazyDyz is offline
post #5 of 16 (permalink) Old 06-03-2018, 01:37 AM
pcdoctorcom's Avatar
I tried this. It does make it quieter for awhile. I'd estimate about 500 miles before the noise returns.
The Additive will eventually wear out just like the oil does. Mainly due to the sheer loads in the transmission.
I went a step further and tried the Lucas 4T Oil, both 10W-40 and the 20W-50 + the stablizer (All full synthetic).
Within 3000 miles, the oil was a little better than the Rotilla T6, but the noise was still there.
The only way I've figured out how to minimize the noise, is to adjust the valves to the tightest allowable specs, IN 0.003"/Ex 0.007". At this tight, they don't make as much noise and the bike runs at it's best. However, your exhaust valves will need to be adjusted almost every 4000 miles. Because of this, I put up with th noise and adjust the valves to the maximums, In 0.005"/Ex 0.009". This way i don't have to adjust them for about 10k miles.
Two things, ...
1- the noise seems to go away after about 10min on the freeway once the bike has heated up.
2- When the bike needs topped off, I use the Lucas 20W-50 full synthetic to help replace maintain it's weight.
Using the Oil stablizer cost too much and doesn't work any better.
Ride your bike, your way, at your speed, for your reasons. Never let anyone else decide who, where, how and why you should ride.
Ride for the love of riding and nothing else and every trip will be an adventure and a memory to be relived over and over.
pcdoctorcom is offline
post #6 of 16 (permalink) Old 06-03-2018, 03:33 AM
Some threads on here say the valves got loose over time, others say they got tight. I say people just arent adjusting them properly. Typically these types of tappets will get looser over time. Ive not touched mine and the bike is on 14000, as long as I can hear them and they're not too loud im happy.
EazyDyz is offline
post #7 of 16 (permalink) Old 06-05-2018, 10:08 AM
Incorrect.
As the valves repeatedly pound themselves into the valve seats, the clearance between the top of the valve stem, and rocker arm goes away, hence, valves/rocker arms need periodic clearance correction.
FX4, pcdoctorcom and pickledsugar like this.
post #8 of 16 (permalink) Old 06-05-2018, 12:02 PM
Originally Posted by Psyc0 View Post
Incorrect.
No what im saying is some people swear the gaps get bigger whereas others say they get narrower, which means people just arent measuring correctly as two identical factory built engines cant have one going looser and one going tighter, so its human error.
EazyDyz is offline
post #9 of 16 (permalink) Old 07-13-2018, 01:20 PM Thread Starter
Some say the Lucas stabilizer is going to wear out on me and noises will return. Its been six weeks and probaby 500 miles plus or minus. The bike still runs smoother than the day I got it (7,500 mi). Jury is still out on this but I'm still enjoying the quieter engine and I'm still pro Lucas Oil Additives.
mdhyre is offline
post #10 of 16 (permalink) Old 07-15-2018, 08:27 AM
volusiacrazy's Avatar
I just add a cup of saw dust once in a while to quiet them.
bsmac likes this.
"04" Volusia 800 Limited
"08" C50 W/ Voyager kit
volusiacrazy is offline
