I got tired of valve noise. Here's what I did. - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
post #11 of 16 (permalink) Old 07-15-2018, 08:18 PM
guitarjim's Avatar
The sewing machine has character.
guitarjim is offline
post #12 of 16 (permalink) Old 07-16-2018, 10:55 PM
Originally Posted by Psyc0 View Post
Incorrect.
As the valves repeatedly pound themselves into the valve seats, the clearance between the top of the valve stem, and rocker arm goes away, hence, valves/rocker arms need periodic clearance correction.
Depends on what part is actually wearing. If the cam lobe or rocker face is wearing the clearance will increase.
toekneedee is offline
post #13 of 16 (permalink) Old 07-17-2018, 09:02 AM
The rocker doesn't actually contact the valve, rather the adjuster does, on one end.
On the other, I've never noticed any significant weat on the cam lobes and contact area of the rocker arms.
Usually the valves & seats wear on Japanese motorcycle engines.
post #14 of 16 (permalink) Old 07-17-2018, 06:20 PM
Haven't seen it on the Volusia, but I've seen a few offroad singles that have had the hardfacing worn through on the cam follower/rocker arm. Also have seen where the adjuster puts a slight divot in the tip of the valve stem which will give it more clearance in operation than what it measures with a feeler gauge.
post #15 of 16 (permalink) Old 07-18-2018, 09:33 AM
FX4
FX4's Avatar
Psych0 knows what he is talking about.
My note: I would be concerned about using an oil thickener like Lukas causing premature engine wear during cold starts. Yeah, it may help for a while with warm engine noise but I believe you will find it causes premature engine wear over time.
FX4 is offline
post #16 of 16 (permalink) Old 07-18-2018, 09:36 AM
FX4
FX4's Avatar
BTW: valve ticking on these motors is healthy, be concerned when you have no ticking.
FX4 is offline
