Oil Leak - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 5 (permalink) Old 05-01-2016, 05:46 PM Thread Starter
Oil Leak
I recently dropped my 2005 C50 (on the left side) in an emergency stop, while I was able to ride it home, I have noticed it is now leaking oil on the left side, right below the chrome circle under the pistons. Have I cracked the crank case?? If I have, what does that mean and what are my options?
Thanks
byAnyOtherName is offline
post #2 of 5 (permalink) Old 05-01-2016, 05:57 PM
Looks like mabe that the plug has been cracked,remove it and have a look
gkeefer is offline
post #3 of 5 (permalink) Old 05-01-2016, 05:59 PM
First picture looks like your showing the coolant tank ????????
gkeefer is offline
post #4 of 5 (permalink) Old 05-01-2016, 06:05 PM
Gene's Avatar
Thanks
Hi welcome to VR forums.
Take a minute and introduce yourself a little further over on the new members section. We're glad to have you here.
Just under and inside from the floorboard on the left side is that shifter shaft and seal. That is a common source of an oil leak on that side of the engine.
You can see it more clearly By laying down beside the machine.
That is what I would check first.
It doesn't appear that you have an engine guard or highway bars on the bike so it is possible that damage was done to the alternator cover that is on the left side of the bike.
If that cover is damaged and causing the leak you should be able to see some sort of road rash on it. It is also possible That the left floor board has been bent and caused a problem.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #5 of 5 (permalink) Old 05-02-2016, 06:34 AM
Another possibility is that you cracked the cover and need to replace it and the gasket.
