Valve adjustment on a 2006 C50 - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 24 (permalink) Old 11-09-2017, 10:45 PM
chromedome1954's Avatar
There is a way to set the valves without using a feeler gauge of any kind.
See this:
A friend of mine shows you how.
chromedome1954 is offline
The Following User Says Thank You to chromedome1954 For This Useful Post:
Mr. Johnny... (11-10-2017)
post #22 of 24 (permalink) Old 11-10-2017, 10:06 AM
RiderRon's Avatar
Originally Posted by [email protected] View Post
What is the gap supposed to be
Valve clearance (when cold):
IN. 0.08 - 0.13 mm
(0.003 - 0.005 in)
EX. 0.17 - 0.22 mm
(0.007 - 0.009 in)
RiderRon is offline
post #23 of 24 (permalink) Old 11-10-2017, 01:40 PM
Gene's Avatar
See this: https://www.youtube.com/watch?v=2roc9lzcHxU&t=13s
That method should only be used to get you in the ball park for using the feeler gauges.... NO accuracy with this method.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #24 of 24 (permalink) Old 11-10-2017, 08:28 PM
RiderRon's Avatar
I used that method when I adjusted mine but double checked with feeler gauge and the adjustments were not consistent so I used feeler gauges instead to be more accurate.
RiderRon is offline
