How to guide: VS1400 drive on a VL800/C50 - Page 4 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 3Likes
post #31 of 168 (permalink) Old 05-12-2009, 12:38 AM
Originally Posted by C50nVA
The spacer I have is not the same outer diameter all the way across. One end is about an inch and the other end is about 7/8".
Which side should I take the 2mm from? Or does it matter?
Thanks!
You can't go wrong if you take it from the large end.
C50std is offline
post #32 of 168 (permalink) Old 05-13-2009, 04:17 PM
Drive assembly replacement.
Does anybody in the Fredericksburg VA area know of anyone that has made this mod, and that would be willing do it again on my bike?
sambo67 is offline
post #33 of 168 (permalink) Old 05-13-2009, 06:34 PM
deehal's Avatar
x
what year(s) vs1400 drive is used for this mod ????
deehal is offline
post #34 of 168 (permalink) Old 05-14-2009, 03:43 PM Thread Starter
OregonLAN's Avatar
Re: x
I think they made VS1400s from 1996 to 2002, They all have the same part number for the final drive assembly.
OregonLAN is offline
post #35 of 168 (permalink) Old 05-14-2009, 04:35 PM
1987-2003 VS1400 all share the same part number for the final drive. The parts breakdown shows 87-95 and then 86-03 but the final drive is the same for both groups. The part number is 27300-38845.
ratobin is offline
post #36 of 168 (permalink) Old 06-10-2009, 02:14 PM
Final Drive Mod
I have an 03 Volusia. For clarification, what are my options. There is a guy locally that used a Hamlings drive. I see the C-90 and the VS1400 and this Hamling. Oh and the "DJ" drive. I'm trying to get a handle on where I can get the parts and what I should expect to have in it by the time I'm thru.
hiskid is offline
post #37 of 168 (permalink) Old 06-10-2009, 10:52 PM
deehal's Avatar
Re: Final Drive Mod
The hamling, and dj drive are the entities that modify the drives...
As I understand the c90 drives are realy hard to come by lately... That is why the 1400 is used now... there is a how to on this in a sticky at the top of motors transmissions and drives all about this.....
deehal is offline
post #38 of 168 (permalink) Old 06-10-2009, 11:34 PM
I have a question?
Has any failures been reported due to the shaft splines wearing/breaking? The reason why I am asking is since there is machining being done to the shaft there is going to be some stressed introduced to it from that process. It would seem wise to temper the shaft to reduce the stresses added from the maching process.
Kevin...
kgallich is offline
post #39 of 168 (permalink) Old 06-11-2009, 12:15 AM
Boxwrench's Avatar
None on drives made by Dan Hills (DJ)
But he doesn't machine the spline.
He cuts and shortens and re-welds and trues up the drive better than original.
None so far reported w/ the 1400 drives
Also I believe the 1400 drives someone said gives only a 10% change as to the C90's 14%.
Boxwrench is offline
post #40 of 168 (permalink) Old 06-11-2009, 12:25 AM
Originally Posted by kgallich
I have a question?
The only failures reported have been with unmodified oem driveshafts. The two fellas mentioned here know what they're do'n. Hillis described his process once and it sounded like some sort of heat treating is done.
YZ, who is a machinest by trade, uses a process to buildup up the shoulder area that he turns back, a heating/tempering process as well.
472viper is offline
