Oil Drain Plug? - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 27 (permalink) Old 04-13-2009, 08:43 PM
You know................
It would cost Suzuki the grand total of about 25 cents extra per bike to include a magnetic oil plug as OEM.
And, it would be great PR.
SUZUKI..........ARE YOU LISTENING?
John
Ohcsim123 is offline
post #22 of 27 (permalink) Old 04-13-2009, 09:46 PM
RemingtonNY's Avatar
John
My rear drain plug has a magnetic core in it...
RemingtonNY is offline
post #23 of 27 (permalink) Old 06-03-2009, 10:29 PM
Trent's Avatar
Originally Posted by Swell-Volusia
Thanks.
The new plug is an automobile oil plug with a rubber fabric type washer. Would it be better to use the Suzuki washer or the new washer that came with the plug. I did order the Suzuki plug as a backup plan. I just didn't want to wait 5 days.
I know this is a simple question I just didn't want to leave all my oil on the road if the shorter plug vibrated out or something. I couldn't figure out why Suzuki used such a long oil drain plug. You would think they had a good reason....
The length and magnetic qualities of the drain plug are useful to attract the tiny metal particles that get sheared off from all the moving parts. The rubber fabric washer should be fine, because the washer is really there so you won't overtighten the bolt and thereby crack the case. The washer doesn't prevent a leak, as evidenced by the fact that most of the people on this site have posted testimonials that they don't even use it, and it doesn't leak their bikes.
2006 Suzuki C50T. All OEM.
Trent is offline
post #24 of 27 (permalink) Old 02-11-2016, 06:50 PM
westslopevolusia's Avatar
Suzuki never listens. I don't get the "crack the case" stuff, wouldn't you have to torque down the drain plug really hard to do that? How many VL800/C50 crank cases have you seen cracked in this manner? Seems absurd to me. The VL800 oil drain bolt is in the right side half of the crankcase and I would think you would strip threads before you crack that aluminum.
westslopevolusia is offline
post #25 of 27 (permalink) Old 02-11-2016, 09:24 PM
Gene's Avatar
That washer is there for two reasons:
1. It is sacrificial material so that the sealing surface of the block is not damaged by rotating friction when the plug is tightened and
2. It is a sealing material that is compressed when the plug is tightened to the correct torque
It is the correct torque that holds the plug tight and prevents the threads in the transmission housing from being stripped.
On the boulevard and VL 800, that torque on the drain plug will be a maximum of 15 foot-pounds.
Installing a shorter drain plug then stock will allow great case debris to accumulate in the threads above the end of the plug. That Accumulated debris will cause damage to the threads when a stock drain plug is reinstalled if the debris is not flushed out.
The length of the stock plug is designed to keep the debris out of the threads before the oil is drained.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #26 of 27 (permalink) Old 02-12-2016, 09:27 AM
bipestuff's Avatar
Wow that thread went back a while, but still good information!
<img src=https://www.volusiariders.com/signaturepics/sigpic33430_1.gif border=0 alt= />
2018 Indian Roadmaster
2007 black C50T (traded 2019)
1973 Kawasaki (first bike)
My Gallery
bipestuff is offline
post #27 of 27 (permalink) Old 07-28-2019, 03:27 PM
And here we are 10 years after your very reasonable post and still no magnetic plug or do the 2019's have 'em?
MrLocker is offline
