Issue getting fuel to carb. - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 1 (permalink) Old 08-09-2019, 09:38 AM Thread Starter
Hi guys. I'm getting my bike going again. It sat for several years because I had issues. Hopefully I can get some info and back on the road..... First of all.. we are talking Suzuki volusia 800 2003.... It's charged and ready .. bike will run fine enough with the fuel tank off, and gas being fed directly to fuel line..... Ok cool... when I go to hook up the tank the fuel won't feed from tank.. iv read there's a slight vaccume on the lines, but in my case I removed my pair valves. So once the pair valves are removed is there a vaccume line that hooks up to the lower end of fuel valve/petcock... I hooked up larger fuel line to the top end of fuel valve.(has clamp and metal spring case around line) . My question is is the file valve supposed to have the lower end open or a hose connecting to it or do I need a new petcock fuel valve..( I took apart fuel valve and hit it with compressed air diaphragm looks intact) thanks a bunch guys
Ekimswartz207 is offline
