Upkeep - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 3 (permalink) Old 04-27-2014, 03:25 AM Thread Starter
336floyd's Avatar
Upkeep
Hey guys i have a 2006 Boulevard with about 15k miles i bought it a couple months ago and changed all the fluids what other regular maintenance do i need to start ??
Just Floyd
336floyd is offline
post #2 of 3 (permalink) Old 04-27-2014, 06:36 AM
Welcome to the site. My son just purchased a low mileage (3,000 miles) used 2006 C50 last year, so the memories are still somewhat fresh. We did not have any maintenance records and consequently assumed nothing had been done.
We changed oil, coolant, rear drive shaft, and brake fluid.
Checked but did not replace the air filter,
Installed a SS brake line,
Lubed the rear propeller gear,
Adjusted the clutch,
Checked brake pad wear- both front and back were ok (your fronts may be getting close)
Lubed the ignition switch,
Did a valve adjustment, and while we were at it - replaced spark plugs,
We have not replaced tires yet- checked and saw no cracking. I replaced my OEM tires at 13,000 miles, so those may need to be replaced soon.
The battery had recently been replaced so nothing done there- while the OEM batteries have experienced long life, I'd keep an eye on it if yours is an original.
Radman is offline
The Following User Says Thank You to Radman For This Useful Post:
336floyd (05-05-2014)
post #3 of 3 (permalink) Old 04-27-2014, 06:59 AM
Ashamsi's Avatar
All of the above, plus replace fuel line.
Also, re the tires, check the date code and if they are too old, replace them even if they have tread left.
Ride Safe
Ashamsi is offline
The Following User Says Thank You to Ashamsi For This Useful Post:
