What is the top speed of your VL-800 - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 31Likes
post #11 of 107 (permalink) Old 03-21-2009, 07:32 PM
bigkillerdog's Avatar
03 Volusia
95 max indicated
bigkillerdog is offline
post #12 of 107 (permalink) Old 03-21-2009, 07:33 PM
I also have an old Seca and I can say, yeah, much faster. The Volusia is a cruiser. It does have some muscle.
JohnneG is offline
post #13 of 107 (permalink) Old 03-21-2009, 08:13 PM Thread Starter
Well thanks guys for the honest opinions, my 95 mph with the windshield & bags sounds just barely ok, I think I'm going to try & run a portabal fuel - air ratio meter on mine to see if I'm any where close to the right fuel air ratio running down the road. You know really 90 is fast enough if---- that's all its suppose to do, I just want the vehicle to give me what it capable of, not less!!
Grayeeagle is offline
post #14 of 107 (permalink) Old 03-21-2009, 08:25 PM
The windshield will slow you down considerably.
JohnneG is offline
post #15 of 107 (permalink) Old 03-21-2009, 08:26 PM
Originally Posted by wehrd1
I can't say now....before the DJ drive that we just installed today...my top speed was about 85 screaming...rejetted, k&n filter, saddlebags w/big windshield.
today after the DJ drive install...i hit 85 w/o even TRYING...and had a lot of throttle left
Oh-Oh........Hot time in the old town tonight!
post #16 of 107 (permalink) Old 03-21-2009, 08:27 PM
Re: What is the top speed of your VL-800
Originally Posted by Grayeeagle
How fast will a VL 800 go, I don't wont to here a lot I think it will or it should go, I have a 2003 VL800, Anniversary edition, 11300 miles, I run Mobil V-twin oil, with factory wind shield & Bags, I weigh 200# I know for a fact the speedometer is 5 mph fast at 70 mph, it tops out at 95 mph (Indicated) on level ground normal wind, I have debaffeled pipes, K &N air filter, drilled air cleaner cover (4) 3/4 holes along the bottom, rejeted carb, Jet size is a #.059 drill, metering rod has 3 washers under it, I run mid range fuel, I don't know what the octane is. It seems to have good all around performance, idle, mid-rang-pulls good from 40 mph in 5th gear. Best mileage is 48.9 on the road, 36 around town. I'm a retired auto teacher so I understand how thing should work. some people claim 110 mph, do I need to find a good mechanic??
I'd say Your machine is at mid ground in the ball park.
post #17 of 107 (permalink) Old 03-21-2009, 09:25 PM
Mr. Efficiency's Avatar
Alls I know is if you ride it routinely over 90 MPH you won't need to worry about getting it any faster.
Mr. Efficiency is offline
post #18 of 107 (permalink) Old 03-21-2009, 09:37 PM
RichisinAZ's Avatar
Had it up to 97 once with a little throttle still left. I chickened out.... a bit scarey. And I verified the speed with my GPS. My speedo reads about 6 mph at that speed.
'08 C50T Red and White
RichisinAZ is offline
post #19 of 107 (permalink) Old 03-21-2009, 09:38 PM
RichisinAZ's Avatar
Had it up to 97 once with a little throttle still left. I chickened out.... a bit scarey. And I verified the speed with my GPS. My speedo reads about 6 mph FAST at that speed.
post #20 of 107 (permalink) Old 03-21-2009, 10:48 PM
Sidewalk's Avatar
When you see an error in your post, there should be a little "edit" box in the upper right corner. Click that, change whatever, hit submit and your original post should be what you wanted.
After 3 years on here, I figured that out a few days ago. Big help!
Sidewalk is offline
