Quick turn throttle mod - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 2Likes
post #1 of 11 (permalink) Old 10-31-2019, 01:01 PM Thread Starter
Anyone see the zip tie or PVC mods being done to take the throttle from a 1/4 turn to 1/5 or even 1/6? I am getting new Avon grips and am wondering if anyone has done these mods and how they changed the feeling of the bike.
ipartola is offline
post #2 of 11 (permalink) Old 10-31-2019, 01:52 PM
I can't imagine having a throttle that responded that quick.
It would almost be akin to having a throttle toggle switch that went from idle to wide open.
There can be times when a situation causes you to turn the throttle a little more than you wish, such as hitting a pothole, or maybe having no choice but to hit an obstacle.
Personally, I don't want my bike to go full throttle so easily.
YMMV.
7 Jack Russell's
bbqjoe is online now
post #3 of 11 (permalink) Old 10-31-2019, 02:27 PM Thread Starter
When cruising long distances on major highways I sometimes set my cramp buster to where at normal wrist position it starts at about 1/8th of a turn already engaged. Makes going 75-80 a lot easier on the wrist. These aren’t liter inline 4 sport bikes capable of wheelies, so I don’t think it would run away from you if you blip the throttle accidentally. I think it’d be safer than my cramp buster trick since I have to twist my wrist forward to stop which takes a little getting used to. From what I’ve seen with other bikes, going to 1/5 is very manageable, while 1/6 is where you might run into trouble.
ipartola is offline
post #4 of 11 (permalink) Old 10-31-2019, 05:50 PM
Chedell's Avatar
I use a throttle lock.
Chedell is offline
post #5 of 11 (permalink) Old 10-31-2019, 06:11 PM
I do too.
There's many different styles.
I use the brakeaway on both of my bikes.
When the lock is set, it can be released at the press of a button, or it will release as soon as you begin to apply the front brake.
Ragdude likes this.
7 Jack Russell's
post #6 of 11 (permalink) Old 11-01-2019, 04:55 PM
bsmac's Avatar
Mine has a little thumb lever to unlock it... Do you have a brand or model number for this kind?
**Edit**
<facepalm> OK, I didn't realize 'breakaway' was the brand name. I'm going to have to start reading all of the words when someone uses them :-p
Hey, careful, man, there's a beverage here!
bsmac is offline
post #7 of 11 (permalink) Old 11-03-2019, 09:24 AM
DickB's Avatar
I tried different throttle locks on a previous bike and didn't like them. For the price of a Breakaway I got an electronic cruise control which I really like, although admittedly installation was not easy.
2006 blue M50
2019 Honda Super Cub C125
1983 Wetbike (sold)
DickB is offline
post #8 of 11 (permalink) Old 11-03-2019, 01:12 PM Thread Starter
What’s this? You can get actual cruise control, not just a throttle lock? How/where/how much/shut up and take my money!
Ragdude likes this.
ipartola is offline
post #9 of 11 (permalink) Old 11-04-2019, 06:22 PM
DickB's Avatar
https://www.volusiariders.com/47-cus...tallation.html
2006 blue M50
1983 Wetbike (sold)
DickB is offline
post #10 of 11 (permalink) Old 11-12-2019, 12:03 PM Thread Starter
So an update. Over the weekend I installed new grips (Avon Contours) and did the zip tie mod. My Volusia had aftermarket grips on it that were 1.65" in diameter and I had heated covers on top of that making them like 1.75" total. These were too big for my hands, so I went with Avon's 1.45" grips, making them 1.55" total. Surprising thing: the Avon grip's throttle cam was already slightly larger than the previous set. This was minimal, but just something to note.
After getting everything else set up (Avon comes with two cams, one for Honda, one for other Japanese brands, and you need to glue the cam on first), I cut a zip tie of appropriate size and glued it on with superglue one section at a time. The cables already will hold it with tension, the glue is there just to prevent it from sliding side to side. Took some time as I did about 0.25" at a time, moving from one end to the other and letting the glue cure. The end result was that the radius of the throttle cam was larger by about 0.1" or so. Once installed, this resulted in reduction from roughly a quarter turn to 1/5 turn from closed to WOT.
I took it for a couple of drives. Around town the bike gets into the power band just that much easier. It does not feel jumpy at all, just results in a smooth transition from idle to power band. The difference is small but noticeable and pleasant. I also did about 60 miles on the highway last night going between 60 and 88. Here the difference is a bit more pronounced. I can cruise at 65 on a flat straight stretch just off idle in 5th which is nice, but the biggest difference is that when I needed to pass four busses in a row I could hold my wrist in a much more comfortable position to get to the peak of the powerband. With the old setup my wrist would be at a silly angle, requiring me to either just suffer that or turn the throttle, then hold it in place with my palm while moving my hand further up and then turning it some more. I am happy with this mod, though if I ever do it again, I'd probably add a next size up zip tie to get the angle from 70 degrees to more like 65.
Overall, so far I am glad I did this. It also makes me wonder why so few manufacturers make progressive cams to keep the rpm uneven but the torque curve flatter. Avon can clearly ship two cams, why not two dozen with different profiles. For a high revving bike you could get a cam that gets from idle to 5,000 rpm quickly but then gives you more room from 5,000-15,000. For a long stroke V-twin it could be the opposite: slow ramp up in the first half of the cam, followed by a quicker ramp up at the high end. In either case, I am glad I did this mod that cost me a total of $45 for new grips and $0.25 in glue (the zip tie didn't even cost me a penny since it was a cut off end).
ipartola is offline
