Is a braided brake line worth it? - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 9Likes
post #11 of 24 (permalink) Old 05-08-2019, 10:03 AM
My 2008 C50 also has the original line, 5400 miles on the odometer. Should I replace the break line now, or is it safe to ride it for another season? Master cylinder was rebuilt about 7-8 moths ago when I bought my bike; break fluid had to have been replaced at the time as well.
Is this a job better done at the shop, or I can do it myself considering I've never replaced break fluid or bled a bike break line before. I probably have most of the tools necessary, except a torque wrench and Brake Bleeder and Vacuum Pump? I also have both the owners and service manuals.
post #12 of 24 (permalink) Old 05-08-2019, 11:00 AM
The service interval is to REPLACE the rubber brake line every 2 years, regardless of mileage. The rubber is porous and it allows air to move in and out. Air has trapped moisture which gets absorbed by the brake fluid, contaminating it and lowering its boiling temperature. This will cause brake failure if you overheat the fluid and the moisture boils off and creates a gas pocket in the system.
Replace the line and fully flush the system asap.
FireManC50 (05-09-2019)
post #13 of 24 (permalink) Old 05-08-2019, 12:04 PM
You can do it with a wrench, rubber tube and a jar.
Drain the system, replace the hose first. Then fill the reservoir, put wrench on bleeder valve. Shove rubber tube over valve, and other end in jar. Open valve and squeeze handle a few times, holding it in the last time. Open valve and close it when there's no pressure in the handle. Refill fluid and repeat till only clear fluid comes out with no air bubbles. Make sure you keep reservoir full or you have to start again.
The Following User Says Thank You to scorpion46 For This Useful Post:
post #14 of 24 (permalink) Old 05-08-2019, 12:48 PM
Skrapiron: maintenance chart (see attached), calls for break line replacement every 4 years... is it just a good practice to replace the break line more often?
In any case, I will be ordering a break line soon and setting aside a weekend to do all this work.
post #15 of 24 (permalink) Old 05-08-2019, 12:51 PM
Thanks! Sounds easy enough... probably is after I do it the first time...
post #16 of 24 (permalink) Old 05-08-2019, 04:38 PM
He's very knowledgeable. With all the stuff in his head, it was probably just a simple slip. You can trust his wisdom. 4 yrs would be the max, thats my opinion.
post #17 of 24 (permalink) Old 05-08-2019, 08:14 PM
So I've ordered Galfer Brake Line Kit, picked-up some DOT 4 break fluid and a case of beer. Next weekend will be busy
Do i need to changer braided line as often at the OEM rubber line?
post #18 of 24 (permalink) Old 05-09-2019, 08:36 AM Thread Starter
They're supposed to last longer.
If you find air trapped in the system which you cant get out, either remove the caliper and raise it above the bike (hang off the rafter) for a couple of hours, or pull the brake lever in, cable tie it and leave it overnight. This guide is pretty fool proof, not done a full bleed and replace on motorbike but did it with hydraulic bicycle brakes and its just the same.
EazyDyz is offline
The Following User Says Thank You to EazyDyz For This Useful Post:
post #19 of 24 (permalink) Old 05-09-2019, 09:28 AM
Thank you everyone!
Got a quote from a reliable shop: $220+tax for 2 hours of work, no parts included. Considering no special tools required, I will attempt to do it myself.
post #20 of 24 (permalink) Old 05-09-2019, 02:03 PM
What's the difference in the price between rubber and braided? How long do you plan on keeping the bike?
beezer is online now
