M90 saddlebags - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
post #1 of 15 (permalink) Old 04-22-2019, 11:48 PM Thread Starter
Highbrass's Avatar
M90 saddlebags
Found a nice pair of OEM bags & hardware for an M90
I was wondering if these will fit my 02 VL800 ?
ronken10 likes this.
Highbrass is offline
post #2 of 15 (permalink) Old 04-23-2019, 06:11 AM
Not without modifications.
Skrapiron is online now
post #3 of 15 (permalink) Old 04-24-2019, 09:44 PM
ronken10's Avatar
But they might fit my 2015 C90 which has a similar frame to the M90. If you decide not to get them let me know. Most all bags need some kind of modification or at least new bolt holes that match the mounting brackets. Trick is making it strong enough. I used a rigid metal strip with holes down it's length Cut it to go inside the bag and match the holes to the bike holes. Great support with no fuss. You may also need longer bolts and spacers between the bags and the fender. You can do it! ..... But if you don't , let me know...... PS. Do one bolt at a time because they are much harder to thread back in if you remove two or more.
NECESSITAS NON HABET LEGEM
2015 C90T BOSS. Power I don't need and weight I can barely handle. Love a challenge.
ronken10 is offline
post #4 of 15 (permalink) Old 04-27-2019, 10:57 PM Thread Starter
Highbrass's Avatar
I went ahead and got them .. Being shipped
I will look to see if its worth the hassle and if not I will get back to you RONKEN
post #5 of 15 (permalink) Old 04-28-2019, 10:52 AM
meierjn's Avatar
I had a set of these on my M90. The bags looked great but were a little on the small side. They are also compatible with the M109. I'm looking for a set of decent bags for it now.
Living the dream...
meierjn is offline
post #6 of 15 (permalink) Old 04-30-2019, 07:53 PM Thread Starter
Highbrass's Avatar
I got them in today...
In Fantastic shape. The mounting holes are a bit farther apart than the stock mounting bolt position.
If anyone has any suggestions on a good way to do it ?
Being an electrician, I had the idea to use some unistrut as a mounting rail, then use strut nuts to mount the bags to the rail ?
It should keep everything at the correct height ... I think ??
If I go that route I will take pictures ...Might give someone an idea
post #7 of 15 (permalink) Old 04-30-2019, 08:01 PM
You are in uncharted territory my friend. I would be concerned about the strength of the mount and the correct height to keep it from dropping on the exhaust. It is all trial and error from here.
post #8 of 15 (permalink) Old 04-30-2019, 09:47 PM Thread Starter
Highbrass's Avatar
From what I measured it should work quite well.
BUUUUTTTT I have Irish Luck !
post #9 of 15 (permalink) Old 05-01-2019, 10:41 AM
Have some Irish coffee before you start and you should be good. Let us know how it goes and good luck. (Hiccup)
post #10 of 15 (permalink) Old 05-01-2019, 12:08 PM
how about some pics of the bags...
