Gear indicator - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 6Likes
  • 6 Post By DickB
post #1 of 9 (permalink) Old 09-03-2018, 11:19 AM Thread Starter
DickB's Avatar
Gear indicator
I installed a gear indicator. I did not want to just tack it on someplace, so I installed it in the LED panel. I was going to try to remove just the Neutral LED and replace it with the gear indicator, but the indicator was a bit too big. So I replaced the whole panel. I got some LED indicators to replace the High Beam and Low Fuel indicators. I had also gotten Turn Signal indicators, but mounted them up on the speedometer for better visibility.
To make the new panel, I first fitted a cardboard form, then used it to cut out some sheet aluminum, which I bent up with a vice. I painted the front of the aluminum black and fitted a blue acrylic face. The blue acrylic makes the indicator easier to read, as it blocks all but blue light from reflecting off of the 7-segment display face.
There are at least three different types of these indicators. One type uses a magnet on the shift mechanism and a pair of sensors mounted nearby. Another uses the tach and speedo signals to "learn" the gear ratios. This one plugs into the diagnostic connector and gets its info from the ECU.
2006 blue M50
2006 blue Yamaha Vino 125 scooter
1983 Wetbike (sold)
DickB is offline
post #2 of 9 (permalink) Old 09-03-2018, 12:36 PM
Jeepin04's Avatar
That looks awesome! Great job!!
Sent from my SM-G955U using Tapatalk
Jeepin04 is offline
post #3 of 9 (permalink) Old 09-03-2018, 01:37 PM
Nice job.
post #4 of 9 (permalink) Old 09-04-2018, 06:47 PM
coffee man's Avatar
Great seeing the work of a talented fabricator.
2015 Black FJR ABS
David
coffee man is offline
post #5 of 9 (permalink) Old 09-04-2018, 08:54 PM
got talent...nice work...enjoy.
post #6 of 9 (permalink) Old 09-05-2018, 07:46 AM
Looks great.
I have an '08 C50.
Paraquat is offline
post #7 of 9 (permalink) Old 09-05-2018, 09:20 AM
bsmac's Avatar
Damn good work....
Hey, careful, man, there's a beverage here!
bsmac is offline
post #8 of 9 (permalink) Old 09-09-2018, 08:43 AM
I joined just so I could ask if that gear indicator precludes the use of a fuel processor due to it plugging into the ECU directly?
Otherwise, that looks amazing.
elricfate is offline
post #9 of 9 (permalink) Old 05-29-2019, 02:49 PM
seen these on ebay for $34
are these actually plug and play? I could benefit from one
rabies is offline
