Tsukayu Fairing Installation - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 44 (permalink) Old 02-26-2011, 04:28 PM Thread Starter
Update:
The Tsukayu fairing is designed for Memphis Shades windshield mounts, and if You want to use the Suzuki C50 factory windshield mount, You'll need to do some fab work.
The Suzuki mount is 15-1/4" wide, and the fairing is designed with a 13-1/2" wide mounting cavity, hence the fab/welding needed.
I have the factory light-bar as well, and that precluded fabricating any "bolt on" reduction brackets, since those would project the fairing forward, which interferes with the factory light-bar.
Below is a rough sketch, and the measurements shown are sufficient to allow the factory bracket to fit inside the mounting cavity, that is, after cutting the welds, shortening the upper and lower bars, and re-welding .
Of course, the bolt center specs of the mounting tabs must be maintained, as well as the lightbar mount tab specs.
BTW: the difference between the fairing cavity width measurement 13-1/2", and the proposed bracket width of 12-5/8", permits use of the Tsukayu "quick release brackets".
*Feel free to use My sketch as needed, for modding of Your own bracket mounting system*
post #2 of 44 (permalink) Old 03-01-2011, 04:34 PM Thread Starter
Took my windshield bracket to a professional welder today, because the metal should be MIG or TIG welded with a high duty cycle welder, and My MIG welder is but a 110 volt, 88 amp, 20% duty cycle.
I also have a 220 volt AC stick welder, but that type of welding is for thick heavy steels, such as snow plows, farm equipment, etc.
This weld shop owner actually insisted on cutting the old welds, shortening the bars and re-welding, thus restoring the bracket to factory style design.
First welding company that I stopped at was much higher on pricing, and they were not keen about cutting previous welds.
They wanted to cross-cut and butt weld the frame bars, which imo, would likely shear off at some inopportune moment in time.
Hopefully, the bracket should be a bolt-on affair when complete, sans a couple holes to drill.
I'll take a photo of it and post the image after the weld shop is finished shrinking the bracket to my specs.
*Hey Special Ed & Mr E: The guy doing the weld job rides a BMW 1200!
post #3 of 44 (permalink) Old 03-02-2011, 05:21 PM Thread Starter
Got the bracket back this PM, and with very little chrome dissipation from the welding heat.
I simply touched it up with silver model paint.
Surprise, surprise! The bracket literally fell into place as if it was engineered to fit.
No heating or bending..... it was worth the effort to make a sketch for the welder/fabricator!
I'm taking pics as I go along, and I'll post the entire adventure when it's completed.
post #4 of 44 (permalink) Old 03-02-2011, 08:32 PM Thread Starter
Tell ya what....I'll post what I have now.
First frame shows that 15-1/4" Suzuki W/S bracket will not fit inside fairing cavity.
Frame two shows 12-1/2" modified bracket now fits inside of fairing cavity.
Frame three shows that corner of chromed light-bar cover needs a small amount of plastic removed on both ends.
Frame four shows modified windshield mount successfully fitted to the fork crowns.
Frame five shows the modified width of the windshield mount, installed.
Modified from 15-1/4" wide to 12-1/2" wide.
BTW:local professional welder (David S) did a fantastic job, and I paid him a $100 bill for his efforts.
post #5 of 44 (permalink) Old 03-02-2011, 09:15 PM
Doncha love it when a plan comes together?
472viper is offline
post #6 of 44 (permalink) Old 03-02-2011, 09:21 PM Thread Starter
Welp, I thought.......Viper pulls off this sort of gig all the time.......
Why shouldn't I too?
post #7 of 44 (permalink) Old 03-03-2011, 09:08 AM
mtmous's Avatar
Can you now use some spacers if you ever want to put the oem windshield back on?
2012 Yamaha Roadstar
2008 Suzuki C90
mtmous is offline
post #8 of 44 (permalink) Old 03-03-2011, 09:58 AM Thread Starter
Possibly, but I'd simply find another bracket on fleabay or at a boneyard.
The Tsukayu fairing is designed to use a Memphis Shades windshield mount, but I preferred the heavier duty Suzi factory W/S bracket.
post #9 of 44 (permalink) Old 03-03-2011, 08:10 PM
Studly's Avatar
...and the pictures of it on the bike?
Excuse me? Excuse me, senor? May I speak to you please? I asked for a mai tai, and they brought me a pina colada, and I said no salt, NO salt for the margarita, but it had salt on it, big grains of salt, floating in the glass...
Studly is offline
post #10 of 44 (permalink) Old 03-03-2011, 08:12 PM
Boxwrench's Avatar
ya!
Boxwrench is offline
