Throw overs converted to bolt on - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 28 (permalink) Old 05-21-2010, 02:44 PM Thread Starter
imagineer's Avatar
Several people have asked me about how I converted the throw over bags to bolt on. Since Iím too lazy to take everything off the bike to take pictures, I whipped up a quick CAD model showing how I did it.
I started with an inner panel made from 1/8Ē thick aluminum, cut to fit the inside shape of the saddle bag. I took my time making this part so it fit the inside of the bag tightly
This rendering shows the relationship of the inner panel to the rest of the parts, including the stock chrome saddle bag support frame.
Here the inner panel is installed inside the saddle bag (you canít see it) and ľ-20 hardware is protruding through. Note, the bolts I used are all flat head and the holes drilled in the inner panel are countersunk so there is nothing sticking out inside the saddle bag.
This shows the spacers I cut out of a cheap polyethylene cutting board. I got lucky and found a $3.00 cutting board that was the same 3/8Ē thickness of the chrome bag support. Both spacers are sized and located such that they fit tight inside the chrome support frame. These serve to locate the bag on the chrome support as well as providing a surface for the clips to be tightened against. There are two counterbores on the top spacer. These are so I can bolt the spacer to the bag such that it stays attached to the bag when I take the bags off. I did this so there would be fewer loose parts when removing or installing the bags.
This shows the clips used to hold the bag to the chrome support frame. Each clip is made from 1/8Ē aluminum. The bottom clip is bolted through the bag and inner panel and does not need to be loosened to remove the bag. The top clip does need to be taken off to remove the bags. The location of the top spacer and clip also serve to limit the bags vertical movement.
This is a shot inside the saddle bag, showing the inner panel and hardware.
The last thing I did was cover the aluminum inner panel with adhesive backed speaker box carpet to protect anything bouncing around inside the saddle bags.
The end result is clean and you can barely see any of the spacers, clips or hardware. Iíve added a home made aluminum 7/16Ē wrench to my on-board tool kit should I need to remove the bags when on the road.
'05 C90 Debadged, Naked Jugs, Custom Pipes w/ Street Glide Mufflers, Cobra FI2000, K&N Filter, SLOB Mod, MS Batwing, Hardstreet Slim Bags, Custom Rear Fender w/ VTX Tail Light & Frenched Plate, Trunk, Pass to flash garage door opener, custom made shift & brake levers, tachometer
'85 Honda VF700C Basket Case.
"There are no simple projects"
imagineer is offline
The Following 7 Users Say Thank You to imagineer For This Useful Post:
Bull Avard (06-10-2017), daycruiser21 (03-30-2014), FutureE9 (03-20-2012), grunt69 (05-28-2013), Jefduro (04-22-2012), Kyleh1214 (12-12-2012), scorpion46 (10-25-2012)
post #2 of 28 (permalink) Old 05-21-2010, 04:29 PM
wehrd1's Avatar
and i think the CAD rendering is MUCH clearer & understandable than the visibility of the actual photos would have been.
thanks.
Hey MODS>>>>> can we do another sticky in the MODS section??
and imagineer...you may want to put that link in your SIGNATURE line
(kinda like Phl0ater did re: his bag mod in his signature line)
wehrd1 is offline
post #3 of 28 (permalink) Old 05-23-2010, 10:36 PM
Jayburdd's Avatar
Nice work, reminds me of the old days sitting on my butt all day with AMADACAM, .
Did I mention I love my Volusia!
Jayburdd is offline
post #4 of 28 (permalink) Old 05-24-2010, 08:06 AM
Excellent job. That's what I've been looking for. Hope I can get my cuts as smooth as the CAD did.
2004 Volusia - Silver and White
Nekkid Jugs and Love It!!
160(DJ) main, 40 pilot, DJ needle 3rd notch
Jesus Still Loves You!!
speedy_fisher3 is offline
post #5 of 28 (permalink) Old 05-24-2010, 08:32 AM Thread Starter
imagineer's Avatar
Table Saw, Chop Saw, Angle Grinder and 6" Vertical Belt Sander...I think I might have used a butter knife too.
post #6 of 28 (permalink) Old 05-24-2010, 10:58 AM
jrclark's Avatar
bookmarked
'03 Volusia
jrclark is offline
post #7 of 28 (permalink) Old 04-22-2011, 11:06 AM
t-man403's Avatar
This should be included in on the "common mods" thread. Or somewhere it doesn't get lost!
t-man403 is offline
post #8 of 28 (permalink) Old 04-22-2011, 11:16 AM
Valleyrider's Avatar
Originally Posted by t-man403 View Post
this should be included in on the "common mods" thread. Or somewhere it doesn't get lost!
+1 sticky!
2007 C50T Boulevard -93K and still kicken!
It's not what you ride, it's all about the freedom!
Valleyrider is offline
post #9 of 28 (permalink) Old 04-30-2011, 10:18 PM
anyone wanna make me some of these brackets?
strangedejavu506 is offline
post #10 of 28 (permalink) Old 04-30-2011, 10:38 PM
Great work, great idea, great drawing.
They have been stickied. Thank you very much.
472viper is offline
