Throw overs converted to bolt on - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 28 (permalink) Old 04-30-2011, 10:59 PM
Great write up!!!!! I did something similar several weekends back after seeing a similar post here. I used 1/8th inch aluminum diamond plate I bought on clearance at a metal wholesaler and cut it to fit the back (outside) of the bags with the pattern facing the leather. Then I drilled holes and permanently attached the formed plates to the backs of the bags by using 25 ish 1/4 inch pop rivets per bag. I riveted from the inside so all is flush inside the bag. I then drilled holes in the plate/bag combo and hard mounted them to the bike. By doing it this way I was able to avoid buying brackets and it places the bags closer to the bike which I wanted personally. As for strength your setup is likely stronger however I travel 40 ish miles each way to school at least 3 days a week with prolly 30 lbs of books in a bag no wobble no sag. I also put a 20 pack of coke in one bag and 2 gallons of water in the other yesterday and rode about 20 miles without any issues at all and when I looked at the bags on the highway and when I got home they showed no sag or signs of stress at the rivets.I do have to say all those rivets inside the bag with a manual rivet gun gets hard on the hand and took about 2 hours to complete. Not as pretty as your setup but it is functional which is what I was going for and you cant tell it isnt pretty unless you stand or squat and peer at the backside of my bags.
helix149 is offline
post #12 of 28 (permalink) Old 04-30-2011, 11:00 PM
PhL0aTeR's Avatar
Originally Posted by t-man403 View Post
This should be included in on the "common mods" thread. Or somewhere it doesn't get lost!
i tried to add it, but im unable to edit my post to do so
PhL0aTeR is offline
post #13 of 28 (permalink) Old 04-30-2011, 11:20 PM
You can't cut the url and paste it into your thread?
That may be a thing where you can't edit after a certain amount of time. If you can't I probably can.
472viper is offline
post #14 of 28 (permalink) Old 04-30-2011, 11:51 PM
PhL0aTeR's Avatar
nope... got no edit button, period... and if it requires me asking a mod to do it each time, it will most likely die.... lol
PhL0aTeR is offline
post #15 of 28 (permalink) Old 04-30-2011, 11:58 PM
t-man403's Avatar
I put it in the "Post Your Home Made Mods" thread.
t-man403 is offline
post #16 of 28 (permalink) Old 05-01-2011, 12:01 AM
I put it in Phloater's thread, under General, right below Rigid Bag Mount.
The thead won't die as long as it's stickied.
472viper is offline
PhL0aTeR (05-01-2011)
post #17 of 28 (permalink) Old 05-01-2011, 12:19 AM
t-man403's Avatar
I've been asking permission to copy and paste into the "Post Your Home Made Mods" thread so that the ideas don't vanish.
"imagineer" has done a really good job on a couple things that should stay where easily accessed.
t-man403 is offline
post #18 of 28 (permalink) Old 05-01-2011, 10:20 AM Thread Starter
imagineer's Avatar
Permission from who?
'05 C90 Debadged, Naked Jugs, Custom Pipes w/ Street Glide Mufflers, Cobra FI2000, K&N Filter, SLOB Mod, MS Batwing, Hardstreet Slim Bags, Custom Rear Fender w/ VTX Tail Light & Frenched Plate, Trunk, Pass to flash garage door opener, custom made shift & brake levers, tachometer
'85 Honda VF700C Basket Case.
"There are no simple projects"
imagineer is offline
post #19 of 28 (permalink) Old 05-01-2011, 03:14 PM
t-man403's Avatar
imagineer
Would you mind if I copied and pasted to the "home made mods" thread. Even your hard mounting soft bags is awesome as well. Would like to put that in there as well. This stuff is to good to lose.
Sure. I'm happy to contribute.
'05 C50 "There are no simple projects"
A "Sticky" Excellent!!
t-man403 is offline
post #20 of 28 (permalink) Old 05-15-2011, 03:18 PM
RemingtonNY's Avatar
+ 1
RemingtonNY is offline
