How to Install LED Flasher - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 38 (permalink) Old 04-15-2011, 10:27 PM
Farmer's Avatar
Got my flasher today going to attempt to install it tomorrow
Farmer is offline
post #22 of 38 (permalink) Old 04-19-2011, 02:32 AM
I've seen lots of different LED flasher relays out there for sale, anyone know if there is much difference in them? I haven't seen the Grote one locally, and online it's $20, I've seen plenty of others for less than $10 locally, just don't want to fry anything !
BC Rob is offline
post #23 of 38 (permalink) Old 07-23-2011, 12:03 PM
Ogre67's Avatar
Originally Posted by apollo View Post
I'm planing to up grade my rear turn signals to l.e.d's. With this mod will my front stock signals flash at the same rate?
I am installing led arrows on my fairing but keeping the rear stock turn signals so I have the same question. Will my stockers still flas at the same rate? I plan on installing driving lamps in the original front singal location.
'05 C50 Red & Black-M/S Fats & Transformers Autobot emblem, Backrest, OEM Crash Bars, Kury Dually pegs with longhorn mounts, Custom luggage rack, auxiliary fuse block, wolo bad-boy, Army Surplus Ammo Can Saddlebags (dead-broke wrist pin)
07 C90T Black-Kury Long horn mounted highway pegs, custom sound system, ABS Trunk, Cobra bars and Slash-cut exhaust, LED Spots, LED Fogs, Warning Strobes, More stickers than a sane person would have
Ogre67 is offline
post #24 of 38 (permalink) Old 09-06-2011, 12:21 AM
Originally Posted by PhL0aTeR View Post
im well aware of what LEDs do to flasher circuits, just wanted to make sure thats what was going on.
I had LEDs on the busa, but never cared about the rate of flash, my buddy was a bit more anal about it so we just wired in resistors when we changed out his signals.
Originally Posted by chevelle69 View Post
By putting in resistors in to the system will draw the same amount of power just insted of the light drawings more you are making the resistor to disipate it in heat. By changing the realy you run at less draw but the same flash rate.
Indeed, putting the extra resistor undoes the advantage of low power draw of an LED. The extra heat generated by the resistor, if not dissipated, may be hazardous too.
Why do LED turn signals flash at a higher speed? When both the bulbs are working, they draw a certain amount of current. If one of the bulbs fails, that bulb draws no current. Flasher is designed to sense lower current draw and flash at a faster speed. The purpose is to tell the driver that one of the bulbs has failed. In older cars, when your turn signal bulb failed, there was no way for you to know without actually looking.
Since LED bulbs draw much less current than tthe conventional incandescent bulbs, your flasher thinks tha one of the bulbs is out, triggering a faster rate of flash.
If you can disble the current sensing part of the flasher circuit, your LED bulbs should work fine with the stock flasher. The key is whether you can take thew flasher out and open it without damaging. That done, the other challenge is to find out the part of the circuit that senses current draw.
Also flashers work with a certain minimum current draw. If you replace all for turn signal bulbs, the total current draw might be less than the minimum required to make the flasher happy. In that case, even disabling or bypassing the current draw sensing circuit won't help. The only option is to replace the OEM flasher with an LED flasher.
To answer the question raised by Ogre67, the new flasher will work fine with any mix of LED and conventional bulbs as the minimum current required for the LED flasher is much lower. If you have one or more conventional bulbs, the minimum current requirement is sure to be met.
Yaatri is offline
post #25 of 38 (permalink) Old 05-05-2012, 01:36 AM
What about this flasher, is it really just a plug and play?
Suzuki Motorcycles M109 M109R M1800R Turn Signal Flasher rely LED FIX INDICATOR | eBay
TURN SIGNAL FLASHER RELAY LED FIX INDICATOR
Developing for M109R AND SUZUKI ALL BIKES exclusive turn signal FLASHER
After you mod LED turn signal, or just exchange LED bulb then you will get flahing too quickly issue.
We create wide range flasher relay. Its stock 7 pins specification. PLUG & GO!
This Plug-&-go wide-range indicator relay capacity from one LED to 100 Watts at a legal flash rate of 70 flashes per minute.
The best and simply way to remove and exchange your stock flasher relay,you don't need any mod or wiring.
PLUG THIS ONE IN AND AWAY YOU GO!
Easy Install
No cutting or Wiring
Also fit stock bulb
Stock type 7 pins
Fit all 2000~ suzuki bike
FITMENT FOR SUZUKI BIKE :
(Fit most Suzuki after 2000' Motorcycles)
DR-Z 400S / SM (00-10)
GSXR 600, 750, 1000 (2000+)
SV 650, 1000 (ALL YEAR)
GSX 650F (ALL YEAR)
TL1000R (NOT the S) (ALL YEAR)
Hayabusa GSXR 1300 (ALL YEAR)
GSF 600 1200 (ALL YEAR)
GSF 650 1250 (ALL YEAR)
GSX 1400 (ALL YEAR)
floydrturbo likes this.
PeaceKeeper is offline
post #26 of 38 (permalink) Old 06-07-2012, 01:43 PM
theonemudstud's Avatar
Easy Install
Also fit stock bulb
Stock type 7 pins
GSX 650F (ALL YEAR)
GSX 1400 (ALL YEAR)
thats is great if it really works.... I am not one for wanting to play with cutting too many wires.. I would love to know if this really works too
2001 Volusia-SKUNK
chrome trimmed tank, fenders
Red LEDS
Debaffled stock exhaust
extra brake lights
Vista Cruise
WWW Metzs
MS Batwing
Pioneer deck with RF speakers
theonemudstud is offline
post #27 of 38 (permalink) Old 06-08-2012, 12:46 AM
Polovision's Avatar
What are those blue floodlights on the front? They start out blue and look like they were adjusted to be brighter.
Polovision is offline
post #28 of 38 (permalink) Old 06-08-2012, 01:44 AM
What are you talking about? And to whom are you talking too?
2001 Volusia-SKUNK
Red LEDS
extra brake lights
Vista Cruise
WWW Metzs
MS Batwing
post #29 of 38 (permalink) Old 06-08-2012, 10:55 AM
SEVEN40iL's Avatar
Ok, so I had installed rear LED turn signals, and nothing up front, and I did get rapid flashing in the rear, which I was ok with.
Now, I have decided to add the LED turn signals to the front. When I connected them to test if they work, this is what they did:
When bike was turned on, the front LED turn signals were on a constant ON, VERY bright. I want to set it up that they are NOT constantly on, but only come on when I use my turn signals.
2nd issue, when I actually use my turn signal, it goes from the VERY BRIGHT CONSTANT ON, to a barely visible flash. When I turn off my signals, it goes back to the VERY BRIGHT CONSTANT ON.
I do have a LED flasher relay that I bought with the LED's, just never got around to installing it.
Would installing it fix my issue? How do I go about changing the CONSTANT ON to OFF?
SEVEN40iL is offline
post #30 of 38 (permalink) Old 06-21-2012, 04:30 PM
Easy Install
Also fit stock bulb
Stock type 7 pins
GSX 650F (ALL YEAR)
GSX 1400 (ALL YEAR)
Well I bought one and it works great .... just installed today ..... I am very happy now....
2001 Volusia-SKUNK
Red LEDS
extra brake lights
Vista Cruise
WWW Metzs
MS Batwing
