License Plate Drop Mod - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
post #1 of 70 (permalink) Old 01-21-2009, 10:10 PM Thread Starter
Butch3131's Avatar
I do not think anybody has done this before, or at lease I haven't seen it posted. So I am going to dub this Butch's License Plate Drop Mod . Original, I know. Let me know if someone has already done this, I do not want to take away somebody's thunder. Anyway, it took me about an hour and is super easy. You can do it without spending a dime. I did have to make a trip to the local autoparts store for some Loctite and some novelty license plate bolts though.
Anyway, like all license plate mods, you start by unmounting the tail light assembly. It is posted on this forum already if you need detailed instructions. Remove the 4 mounting bolts and so you can manuver the tail light assembly around a little bit. While you are under the fender, go ahead and remove the mouting bolts for the license plate bracket.
Next, remove the rear red reflector in the lower portion of the tail light assembly. It is held on by 1 bolt that is part of the reflector. Look inside the tail light assembly and you will see the nut holding it on behind some metal bracketry. The nut is a buger to get to, but that is all that holds is on.
Next, remove your license plate from the mounting plate, then the mounting plate from the bracket. Place the mounting plate upside down where the reflector used to be so the sunken in bolt holes are "inside" the cavity left from the removed reflector.
Amazingly, there is hardly any horizontal play at all. You will be able to move the plate up and down a little before the sunken bolt holes hit the reflector cavity walls. I suggest moving the plate all the way up or down to keep the plate level. When you have decided where you want your plate, use a marker, mark your mounting holes in the reflector cavity. Get the right size drill bit to make a thru hole using the existing Phillips head mounting bolts. Drill your holes. The holes should be wide enough so you won't hit anything inside the tail light assembly.
Using the existing Phillips head mounting bolts, place them back through the mounting plate and into the newly drille mounting holes. You will have plenty of bolt sticking through to thread on to.
If you want to use the existing cap nuts, you will need to add some spacers or washers so the cap nut won't bottom out before becoming tight. Place some Loctite on the threads and tighten them down. Do not tighten too tight because the tail light assembly is made of plastic.
Remount the tail light assembly. Attach you license plate using the existing hardware. I had to put the bolts through the bottom holes because it was to tight for the top holes.
That is it!
You can do what you wish with holes left in the fender from the old placement of the license plate bracket. I left the existing metal green grommets in, spray painted them black, and put some novelty license plate bolts thru them I got at O'Reilly's.
kikig2150 likes this.
2005 Boulevard C50 Black/Blue
"Dream like you will live forever, live like you will die tomorrow."
Butch3131 is offline
The Following 2 Users Say Thank You to Butch3131 For This Useful Post:
BigBry (02-18-2014), TheRealMoleman (09-06-2014)
post #2 of 70 (permalink) Old 01-21-2009, 10:30 PM
KOOL!
looks good really like how its low and outta the way. Also a SLICK look. great job on the mod.
babyhuie is offline
post #3 of 70 (permalink) Old 01-21-2009, 11:23 PM Thread Starter
Butch3131's Avatar
Thank you.
Can somebody tell me how to get the pictures to load in the thread, not as a link. I have fought with it for hours and cannot get it? What is the trick?
I have highlighted the url and hit the Img button but it dosen't work.
post #4 of 70 (permalink) Old 01-21-2009, 11:25 PM
~Capt Creole~'s Avatar
edited...looks like you got it.
Laissez Les Bon Temps Rouler "Let the Good Times Roll"
~Capt Creole~ is offline
post #5 of 70 (permalink) Old 01-21-2009, 11:26 PM
You may be hitting thr URL and not the IMG button
post #6 of 70 (permalink) Old 01-21-2009, 11:29 PM
harryp's Avatar
I've seen it before as I've done it. But I never named it, so you can have the name for the mod.
harryp is offline
post #7 of 70 (permalink) Old 01-21-2009, 11:34 PM Thread Starter
Butch3131's Avatar
Nice! Thank you. I like the Boulevard badge in the old mounting holes. That looks really slick.
I figured out the picture thing by the way.
post #8 of 70 (permalink) Old 01-22-2009, 12:39 AM
jimKo's Avatar
Whomever claims it, I rate that an 8.9 on the modmeter!
Liking how it looks!
|_|_|_|_|_|_|<8.9>|_|_|
jimKo is offline
post #9 of 70 (permalink) Old 01-22-2009, 03:34 AM
I am thinkin I like this style of license plate mod the best so far...got something else to do this winter now!
Check out my site for parts and accessories
hoytheld is offline
post #10 of 70 (permalink) Old 01-22-2009, 06:48 AM
Would everyone please stand up now. great job.
iron_cowboy is offline
