License Plate Drop Mod - Page 7 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 4Likes
post #61 of 70 (permalink) Old 03-01-2014, 03:58 PM
apbronso's Avatar
Removing bolts
How do you remove the retaining bolts for the old license plate bracket? I have seen some of you have covered the holes. I don't want to put reflectors in them. I want to take them out and put in some black plastic caps to cover the holes.
Thanks!
Adrian
Wear sunscreen!
apbronso is offline
post #62 of 70 (permalink) Old 05-23-2014, 04:13 PM
just did this!
super easy thanks!
GrizzMan is offline
post #63 of 70 (permalink) Old 05-24-2014, 06:41 AM
Not bad for 15min of work
Here's a pic
GrizzMan is offline
post #64 of 70 (permalink) Old 06-22-2014, 04:54 PM
Thanks!
Adrian
+1
I was playing around with this yesterday. I have to pieces that protrude from the fender where the license plate mount was. I cannot seem to see how they would be removed. They are sandwiched between the fender and what looks like a fender support but it doesn't look as though that support can be separated.
jmac72187 is offline
post #65 of 70 (permalink) Old 06-23-2014, 08:18 AM
Can't do this mod here in Michigan, (legally), unless additional lighting is added to illuminate the license plate.
2005 Suzuki C50T
"Bugs in your teeth means you had a very good day."
claywheels is offline
post #66 of 70 (permalink) Old 06-23-2014, 09:46 AM
Unfortunately, I think this may be the case in most states. A lighted frame would work well.
post #67 of 70 (permalink) Old 06-23-2014, 10:57 AM
TroyAK's Avatar
TroyAK is offline
post #68 of 70 (permalink) Old 06-23-2014, 02:21 PM
Bama J's Avatar
I bought some chrome spikes from this seller on Ebay for about $5 that plugged the old plate holes, turned out great. The green retainers are inside the fender and can't be removed. I taped off and spray painted them black.
impaler spike from chromedhog-inc | eBay
Here is a pic.
floydrturbo likes this.
2006 H-D Road King Classic
SOLD - 2005 C50T
Bama J is offline
post #69 of 70 (permalink) Old 09-06-2014, 11:09 AM
TheRealMoleman's Avatar
Thumbs up
I finally got around to doing this today, mostly because I had also ordered a chrome fender tip from a seller on eBay and it arrived yesterday, and I figured I would kill two birds with one stone.
The old retaining "bolts" on my 2006 C50 aren't bolts at all; they're really just grommets, sandwiched in between the fender and the metal bracket:
Getting them out was super simple: just remove the rear seat, and lift the fender and jiggle. Sure enough, they fell right out. I couldn't screw anything into them anyway, not without putting something behind them, and I wanted anything I put there to be flush. I ended up putting my old license plate reflector screws there for now.
The finished result:
I actually bought a motorcycle LED license plate light, but it turns out that the brackets for it are too large, so I'm going to have to figure something out. Probably lighted LED screws, as someone else has done.
TheRealMoleman is offline
post #70 of 70 (permalink) Old 04-02-2019, 12:36 AM
Oldbear42's Avatar
I know this is an old thread, but I have something to add to it.
I too have wanted to do this mod for a while. The plate looks goofy sticking up in the air - I have the rear seat, backrest, cargo rack, and pegs removed. I too need to have a light on my plate or I can get ticketed.
While I was poking around to see where I could mount it I noticed that the space under the reflector is quite open - so I built a bracket and mounted a small license plate light. I've included a few "not completed" pictures so others can see what I did. I did drill two holes in the fender to mount the plate mount. I installed 3/8" thick rubber washers between the plate and the fender. I used the clear red part of tuck tape (red construction sealing) to cover (from the inside) the clear part of the rear tail light. And I changed the direction of the plate mounting bolts from what they are in the pictures; I also cut them shorter for better clearance - the picture was just the mock-up.
I also found very shoddy wiring when I moved the tail light - I'll be fixing that too as I wire up the license plate light.
I finished the mod. I added a plate with wings to add the LED amber/red light strips for extra visibility (turn signals and brakes). To fill the holes of the old plate mount I filled them with Sugru (a moldable silicone type glue/rubber). I have the nameplates from when I repainted my 1982 Suzuki GS1100GK (over 20 years ago - my hoarding pays off again) - I covered up the filled holes with one of them. Pays homage to my first road bike.
TRADE: "I do not know why a low idea has been attached to this word; it is to the trades that we owe the things necessary for life." Denis Diderot
Oldbear42 is offline
