Stebel Horn Install Tips and Best Practices - Page 14 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #131 of 133 (permalink) Old 08-10-2015, 08:05 AM
Sleepwalker's Avatar
Originally Posted by rhoov View Post
Got it! I put a new relay on it and that did it. I was kinda suspicious that somehow the relay got shorted.
Thanks again Sleepwalker.
Just happy to help, glad you go it.
2014 C50T
Member of the Iron Horse Cavalry/ABATE of Virginia
"The more I learn, the more I realize I donít know."
ó Albert Einstein
Sleepwalker is offline
post #132 of 133 (permalink) Old 08-10-2016, 07:59 PM
Stebel Nautilus air horn 2007 Suzuki C50
I took the two connectors off of the original horn and connected them directly to the relay. I then ran a wire from the relay to a fuse block that I installed under the seat. Then ran a wire from the 4th connector on the relay to the positive terminal on the horn. I ran a very short wire from the negative terminal on the horn to the bracket. The bracket is a steel corner brace. I had to enlarge the holes for the horn and the bike and cut off a piece of the bracket.
See photos
Mrlease is offline
