Throttle hesitation...why? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 6 (permalink) Old 05-24-2011, 09:39 PM Thread Starter
I just recently noticed I am having a slight hesitation of the throttle when I am switching gears (not every time, but enough that i noticed it might be a problem)
I have an 09 c50 and i have aftermarket exhaust, gman stealth intake, and gman fuel controller...
can this be due to the settings I have the fuel controller at???
ohhh yaah and the bike once yesterday and once today hesitated to start for the first time since ive had the bike
Thanks for your help....
njvt13 is offline
post #2 of 6 (permalink) Old 05-27-2011, 10:49 AM
fuel pump issue maybe? throttle linkage? i would be leaning more towards fuel pump
2009 Boulevard C50
Baron Big Air Kit
Cobra FI2000
Ultimate Seat
DJ Drive
John's Forward Controls
GMan Bushing
kurtw3 is offline
post #3 of 6 (permalink) Old 06-03-2011, 01:24 PM
DrBLVD's Avatar
A slight bog off idle is an indication of a rich pilot jet, or in FI bikes using the GMan, the green to yellow transition adjustment or the green adjustment. Hesistation or bog is also an indication of a vacuum leak. make sure all it tight and secure.
If it were the fuel pump, you would notice it leaning out at higher rpms, making flat spots when you need more gas. Fuel pumps are easy to check, just remove the fuel "rail" from the injector, turn on the ignition and see how much pressure you get, it should be quite high, like over 25 psi (25-50 psi in most mc Fi applications). You can easily check that by placing your thumb over the orifice and it should squirt pretty far. If no squirt, no pressure.
Email GMan, he'll dial you in.
Hesitation to start (hard starting) is an indication of valves being out of adjustment or your FI controller setting.
Seems everything is pointing towards the FI Controller settings. Make sure you got good gas before any adjustments too.
Why use a big word when a diminutive utterance would suffice?
DrBLVD is offline
The Following User Says Thank You to DrBLVD For This Useful Post:
njvt13 (06-06-2011)
post #4 of 6 (permalink) Old 06-06-2011, 12:51 AM Thread Starter
thanks for the prognosis doc...
i didnt even mention hard starting in the post and my bike is having that issue also. I was hoping it was only the fi controller. time to send gman an email. thanks
njvt13 is offline
post #5 of 6 (permalink) Old 06-06-2011, 09:37 AM
Boxwrench's Avatar
BTW when was your last valve job?
Ya know it supposta be done every 7500mi.
Boxwrench is offline
post #6 of 6 (permalink) Old 06-06-2011, 10:14 AM Thread Starter
i only have 3500 miles on the bike.....but thank you for the heads up, now i know
njvt13 is offline
