Suzuki Recall 2008-2010 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 02-26-2011, 01:57 AM   #1 (permalink)
NRider's Avatar
Default Suzuki Recall 2008-2010
Recall on the bikes:
Suzuki Recalls Over 73,000 Motorcycles | USRiderNews
2006 C50T Boulevard
2007 Kawasaki Vulcan 2000 LT
NRider is offline   Reply With Quote
Old 02-26-2011, 08:53 AM   #2 (permalink)
rushbass's Avatar
You can find out the initial details of the recall here: Search for a Recall | Safercar.gov | NHTSA
Search by NHTSA CAMPAIGN ID Number: 11V108000
Here is the recall summary from the NHTSA website:
Vehicle Make / Model: Model Year(s):
SUZUKI / AN400 2008-2009
SUZUKI / DL1000 2008-2009
SUZUKI / GSF1250 2008-2009
SUZUKI / GSX-R600 2008-2009
SUZUKI / GSX-R750 2008-2009
SUZUKI / GSX1300B 2008
SUZUKI / GSX1300R 2008-2010
SUZUKI / GSX650F 2008-2009
SUZUKI / SFV650 2009-2010
SUZUKI / VL800 2008-2010
SUZUKI / VLR1800 2008-2009
SUZUKI / VZ1500 2009-2010
Manufacturer: AMERICAN SUZUKI MOTOR CORP.
Mfr's Report Date: FEB 18, 2011
NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:ALTERNATOR/GENERATOR/REGULATOR
Potential Number of Units Affected: 73,426
Summary:
SUZUKI IS RECALLING CERTAIN MODEL YEAR 2008 THROUGH 2010 MOTORCYCLES MANUFACTURED FROM JULY 2007 THROUGH SEPTEMBER 2009, EQUIPPED WITH REGULATOR/RECTIFIER ASSEMBLIES, SUZUKI PART NUMBERS 32800-41F11, 32800-15H10, 32800-05H11, 32800-41G10, 32800-15H00, 32800-18H00, 32800-05G10, 32800-10G10, 32800-05H20, OR 32800-06G01. SOME REGULATOR/RECTIFIER ASSEMBLIES WERE PRODUCED WITH INSUFFICIENT ADHESION BETWEEN THE POWER MODULE (CIRCUIT BOARD) AND THE RECTIFIER CASE THAT CONTAINS A HEAT SINK TO DISSIPATE HEAT. DUE TO INSUFFICIENT ADHESION, HEAT GENERATED ON THE POWER MODULE CIRCUIT BOARD CAN CAUSE THE CIRCUIT BOARD TO DEFORM, AND LIFT OF THE CASE.
Consequence:
THIS CONDITION CAUSES EXCESSIVE HEAT ON THE CIRCUIT BOARD AND UNCONTROLLED ELECTRIC CURRENT OUTPUT, WHICH CAN RESULT IN INSUFFICIENT CHARGING CURRENT BEING PROVIDED TO THE MOTORCYCLE BATTERY. THIS CAN CAUSE DISCHARGE OF THE BATTERY AND CAN LEAD TO ENGINE STALLING AND/OR A NO-START CONDITION. ENGINE STALLING WHILE RIDING CAN INCREASE THE RISK OF A CRASH.
Remedy:
SUZUKI WILL NOTIFY OWNERS AND SUZUKI DISTRIBUTORS WILL REPLACE THE REGULATOR/RECTIFIER WITH AN IMPROVED PART FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT MARCH 2, 2011. OWNERS MAY CONTACT SUZUKI AT 1-714-996-7040.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Carl - 2005 C50T => 2006 C90 => 2008 Harley FLHTP (103 ci / 6-Speed / ABS)
rushbass is offline   Reply With Quote
Old 02-26-2011, 08:54 AM   #3 (permalink)
rushbass's Avatar
This document lists all the years / models / VINs affected:
http://www-odi.nhtsa.dot.gov/acms/do...1V108-1467.pdf
Maybe a "sticky" is in order for this thread???
Old 02-26-2011, 09:57 AM   #4 (permalink)
Schmiddy's Avatar
Good to know it is finally a recall and not merely a stop sale notice.....
2009 C50SE
Make crime pay. Become a lawyer.
Schmiddy is offline   Reply With Quote
Old 02-26-2011, 07:45 PM   #5 (permalink)
dewey405's Avatar
Send a message via Yahoo to dewey405
Well I guess it says all 2009s, thanks for the heads up, setting up appointment Tuesday for the end of March.
2009 C50 SE(Grey/Dark Grey) 2009-2012
2012 Vulcan 1700 Nomad
dewey405 is offline   Reply With Quote
Old 02-27-2011, 10:08 AM   #6 (permalink)
Agreed!
Psyc0 is offline   Reply With Quote
Old 02-28-2011, 11:19 PM   #7 (permalink)
Due for a 4k service this spring anyhow,hopefully they will have the replacement parts in stock!! Thanks for the heads-up!!
07 C-50 (sold)
08 C-90 Lehman trike conversion (sold)
09 HD Ultra Classic Tri-Glide
Last edited by Dalenut3; 02-28-2011 at 11:24 PM. Reason: needed to add more to post
Dalenut3 is offline   Reply With Quote
Old 03-01-2011, 11:16 AM   #8 (permalink)
The way i had seen this recall the first time i thought my bike WAS INCLUDED in this recall, However, upon CLOSER reading,(and a bit of shut-eye), i CANNOT find anything anywhere that states the VL1500 (C-90) is affected. Much thanks for the info anyhow.Good luck to all who are affected, hopefully it will be a quick-fix at the dealerships.
07 C-50 (sold)
Old 03-01-2011, 08:30 PM   #9 (permalink)
1VaCruiser's Avatar
Thanks for the update on this.
1VaCruiser is offline   Reply With Quote
Old 03-02-2011, 11:00 AM   #10 (permalink)
Jim38's Avatar
This lists the rectifier part no's affected by the recall.
Suzuki recalls more than 70,000 motorcycles for electrical problem - Dealernews
Microfiche here
Alpha Sports - Suzuki Motorcycle Parts Catalog
Don't sweat the petty stuff!
Don't pet the sweaty stuff!
2009 Burgman 650 Exec - current.
C50T 2006 - 2009.
Jim38 is offline   Reply With Quote
