Garage/ Storage/ Shed - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 04-11-2012, 09:38 PM   #11 (permalink)
Max55's Avatar
When we purchased our shed last year it was from Lowe's. They installed the 8 x 10 for 1500.00. You just have to make sure of the door opening orientation when buying an 8 x 10. They wanted to put the opening on the 10 foot side. I made sure that I had it put on the 8 foot side so that I could pull a bike in that's longer than 8 feet.
Even if you get a 10 x 10 you will find that there really isn't much room. You could fit 2 c50's side by side and that would be it. You would still be limited on your options for pulling the bike in. The doors would have at most a 5 foot opening. If you pulled your bike in straight then you wouldn't have a problem. If you pull your bike in at an angle and have to back out on an incline you may find problems.
Make sure you buy a wheel chock so that you can just pull your bike in straight.
You may be able to find a decent used trailer with a drop down rear door for less than the shed.
Neil
Old 04-12-2012, 06:47 AM   #12 (permalink)
Max55's Avatar
If you do go the trailer route. Make sure that you get a 12' long trailer if there is no v-nose. If it is a v-nose you can get away with a 10' long trailer.
Neil
Old 04-12-2012, 10:58 AM   #13 (permalink)
http://www.sheltersofamerica.com/pro...ctid=634&id=12#
larger selection..better prices
http://www.portablegaragedepot.com/index.cfm?catid=72
temporary solution till you decide what you want to do.
Old 04-12-2012, 11:13 AM   #14 (permalink)
mfile2000's Avatar
Neil
Now I have an 8x10 and swear if I had a 10x10 with the doors on the 10 ft side, that would work for me. I opted to keep the smaller bike in the existing shed, and put the bigger bike in a cycle cover, next to the shed. Primarily because I didn't want to spend the money for a good bigger shed and then do the work.
mfile2000 is offline   Reply With Quote
