Engine sound +Check video - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 4 (permalink) Old 06-18-2017, 05:37 PM Thread Starter
Hello guys
can some one told me if is that sound of engine normal?In first video u can hear something like sawing machine (only cam chain was replaced)..in the second video i can still hear some clicking noise from engine, in the second video is cam chain tensioner replaced.I have 47k km (29miles) Very thanks for answer
There is video after Cam chain tensioner replacement
triocz is offline
post #2 of 4 (permalink) Old 06-18-2017, 07:07 PM
Second sample sounds fairly normal, with perhaps one or two valve adjusters set at the maximum clearance.
What is the oil grade that was used when the second video was recorded?
post #3 of 4 (permalink) Old 06-18-2017, 07:40 PM
Video 1: was the engine cold or hot?
Video 2: sounds definitely better than video 1, sounds really good to me, the valves are always noisy on the C50, possibly needs a valve adjustment....
If I remember I'll make a video how mine sounds, mine is a 2016 with 2200 kilometers on the clock, basically a brand new machine
Which oil are you using?
alex_at is offline
post #4 of 4 (permalink) Old 06-19-2017, 03:30 PM Thread Starter
I using oil Castrol 10w40 on both videos is engine hot
triocz is offline
