oil in the coolant - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 4 (permalink) Old 06-17-2017, 06:43 PM Thread Starter
Unhappy oil in the coolant
my 2012 boulevard is getting a little oil in the cooling system....??? clogging up small passages in the radiator.... getting hot and slowly purging coolant out.... 20,000 miles never abused.... is this a head gasket???
Cannonball is offline
post #2 of 4 (permalink) Old 06-17-2017, 08:25 PM
Yes. It is most likely a head gasket issue. There is no miracle in a bottle that you can pour into the crankcase either. It will require a complete tear down and machining of the heads.
post #3 of 4 (permalink) Old 06-17-2017, 10:05 PM Thread Starter
thank you so much scrap iron.....i sent my c50 to dealers to diagnose....they could not find the problem, i also was puzzled being a pretty good wrench myself, i finally looked in the last possible cause, sure enough i looked in the top hose flange of the radiator, and seen what looked like little globs of white grease blocking the radiator passages. i bought a lemon!
post #4 of 4 (permalink) Old 06-17-2017, 11:42 PM
It could be as simple as a bad mechanical seal gone bad
gkeefer is offline
