only one bar - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 7 (permalink) Old 05-19-2017, 07:48 AM Thread Starter
htlong's Avatar
only one bar
I recently changed the spark plugs on my 2004 Volusia limited I didn't check to see if the fuel bars were showing before I started I didn't take it out for a ride after winter storage.
when I lifted the tank to change the plugs could I have disconnected the fuel gage ,or could it be stuck from sitting all winter?
I don't really use the gage I go by mileage but it is blinking is distracting
is there anyway to free up the float?
I'm addicted to Placeboes!!!
htlong is offline
post #2 of 7 (permalink) Old 05-19-2017, 09:02 AM
petec50c's Avatar
I'm sorry that I can't answer your question but hopefully somebody out there will chime in and help you out.
We have great mechanic willing to help out.
Only Bikers understand why dogs love to stick their heads out car windows!
1960 - 1997 = scooter to goldwing
2006 - 2010 = 2006 c50c w/touring accessories and V&HCruzers.
2010 - 08/2015 = 2009 Victory Kingpin Low in sandy graphite gray with Arlen Ness slash down pipes.
08/2015 - Present = 2012 Victory Cross Roads Classic Limited LE in black and white. Serial #66. Stage 1 Exhaust.
petec50c is offline
post #3 of 7 (permalink) Old 05-19-2017, 09:41 AM
would first check the connector...had that happen once when I disconnected the speedo when I removed the tank...forget to reconnect it and that's what happened...blinking bar...hope its that simple a fix for you.
post #4 of 7 (permalink) Old 05-21-2017, 06:49 AM Thread Starter
htlong's Avatar
I didn't disconnect the tank when I changed the plugs but maybe I loosened the connection , the speedo and turn signals still work, the bike sat all winter I had sea foam with the gas it might be stuck i fuel It started up fine do you think seafoam might loosen it up?
htlong is offline
post #5 of 7 (permalink) Old 05-21-2017, 10:38 AM
Maybe remove the tank, turn upside down and shake it
Ragdude is offline
post #6 of 7 (permalink) Old 05-21-2017, 06:21 PM
from what I've heard the sending unit in the tank (floater) likes to break on this bike.
You do know that regular Seafoam isn't a storage additive like Sta-bil? I know Seafoam as a fuel system cleaner.
But if the fuel gauge was working fine before you lifted the tank - I would start to look for a loose connection.
alex_at is offline
post #7 of 7 (permalink) Old 05-22-2017, 06:53 AM Thread Starter
htlong's Avatar
Int check to see if it was working before I know it was working in the fall
I asked the brain trust on here if seafoam was a fuel cleaner or a stabilizer the answer I received was yes
htlong is offline
