2004 VL800 front turn signal replacement (I'm lost) - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 16 (permalink) Old 05-16-2013, 09:48 PM Thread Starter
Hi everyone,
I'm a long-time reader, just joined the site though. I'm in a bit of a jam with my turn-signals. Basically I had a small run-in with the front end of a car that left me with a snapped stem and shattered lamp. I bought the "EMGO bullet" signal pair that I was told would fit my bike. However, when I removed the headlight the connections are different. There's one bullet-style wire connector, and then a 2-prong style. The EMGO's are 2 wires total, both bullet connectors. Am I at a loss here or is there a way to do this? Between that, the blown fuse, dent in my gas tank, tons of scuffs, and a few more annoyances I'm ready to pull my hair out.
Thanks a lot!
JVL
jerseyvl is offline
post #2 of 16 (permalink) Old 05-16-2013, 09:57 PM
03volusiarider's Avatar
Return them, and buy a used signal off e-bay or something. With the EMGO's as 2 wire you would not have front running lights. So IMO not worth the hassle.
03volusiarider is offline
post #3 of 16 (permalink) Old 05-16-2013, 10:45 PM
v0lusia's Avatar
Just some info I've gathered over the years...
There are multiple types of turn signals/running lights some can only be used for one function (turn OR running) others can be used for both functions.
1 wire - one function only - running light OR turn signal
Connections:
  • Connect the one wire to the brown wire on the bike for running light, the light green for Right turn, Black for left turn
    The negative (ground) is made through the mounting bolt, these lights won't work until you connect the bolt to a metal part on the bike.
2 wire - one function only - running light OR turn signal
Connections:
  • Connect the positive wire on the signal to the brown wire on the bike for running light, the light green for right turn, black for left turn.
    Connect the negative wire on the signal to the black wire with white stripe
2 wire - two function - running light AND turn signal
Connections:
  • Connect one of the positive wires on the signal to the brown wire on the bike for running light
    Connect the other positive wire on the signal to the light green on the bike for right turn, black for left turn.
    The negative (ground) is made through the mounting bolt, these lights won't work until you connect the bolt a metal part on the bike.
    If when you test the running light is brighter than the turn signal swap the two positive wires
3 wire - two function - running light AND turn signal
Connections:
    Connect the other positive wire on the signal to the light green for Right turn, Black for left turn.
    Connect the negative wire to the black with white stripe on the bike.
-Twisties give me happy pants
v0lusia is offline
post #4 of 16 (permalink) Old 05-17-2013, 07:39 AM Thread Starter
Thanks for the info guys, I'm still new at this. So what you're telling me is, clip the wire connector on the bike that has a little boxy type of adapter and 2 slots for a plug in it and just wire one of those (black or black+white) to the negative on the turn signal and then just plug the bullet connector into the one that's already there for it?
Thanks a lot,
JVL
jerseyvl is offline
post #5 of 16 (permalink) Old 05-17-2013, 08:15 AM
Please dont cut the wiring harness on your bike. Put the correct turn signal on it.
The Following User Says Thank You to 03volusiarider For This Useful Post:
vballz (05-17-2013)
post #6 of 16 (permalink) Old 05-17-2013, 08:31 AM
Fizgurd's Avatar
If you feel you absolutely need to use this signal, I agree with 03volusiarider. Please do NOT cut up your wiring harness. If you want to cut anything, cut the plug from the busted signal and splice the wiring to that plug, so that the harness on the bike stays in one piece.
I also think you really should return the signals and get a set that does match the wiring for your bike though.
2008 Burgman 400 '08-'15
2003 Volusia Annie '12-'15, De-badged
2006 Vulcan 2000 Classic '15-Current
IBA# 46706
Fizgurd is offline
The Following User Says Thank You to Fizgurd For This Useful Post:
vballz (05-17-2013)
post #7 of 16 (permalink) Old 05-17-2013, 09:10 AM Thread Starter
Good point. My next question is then, is the wiring on the front signal the same as on the rear? I could swap perhaps and try to fabricate a stem
jerseyvl is offline
post #8 of 16 (permalink) Old 05-17-2013, 09:38 AM
Boxwrench's Avatar
Doubt it. Only the front stay on all the time
Boxwrench is offline
post #9 of 16 (permalink) Old 05-17-2013, 11:38 AM
TNrookie's Avatar
The rear signal only has one plug, while the front one has two. I think the connector is the same as the square-ish one with the clip on the front, but admittedly I don't know if you could just plug that one in and leave the other wire just hanging. Anybody?
I do agree with trying to keep the same connectors, however. I've always been scared of the ubiquitous eBay replacement signals just for the simple fact of the wiring issue!
aka RockyStop, TNsmartass
Chairman and Co-Founder, Stebel CYFHMN Club
'02 Nomad 1500
Bikes I Miss:
'04 Volusia (Black)
'07 C50 (Red/Black)
'04 Volusia (Blue/Gray)
TNrookie is offline
post #10 of 16 (permalink) Old 05-17-2013, 12:50 PM
Which side of the front signal did you break? Maybe someone here can find you an OEM signal.
