driveshaft ciclip: what's the trick - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 01-07-2013, 07:36 AM   #1 (permalink)
Default driveshaft ciclip: what's the trick
Hi everyone,
i've been reading tons and tons of handy tips here on the forum! very grateful for that.
I'm currently checking the grease level on the driveshaft and ... i have the hardest time getting the drive shaft taken out.
I removed the grease cap yesterday without problems. now i have to take out the circlip that holds the driveshaft in place.
I have tried a lot of options, but without success.
I'm squeezing the circlip and pushing down a little bit. the circlip almost closes entirely but then ... nothing else. I can't move any deeper or I can't really pull the shaft out.
What am I not doing right?
how can i get the old grease completely off? just by using a cloth?
much appreciated all.
Hugod is offline   Reply With Quote
Old 01-07-2013, 08:43 AM   #2 (permalink)
mtmous's Avatar
snap ring pliers available at any auto parts store.
Jim & Vickey 2006 C50C x2
mtmous is offline   Reply With Quote
Old 01-07-2013, 09:05 AM   #3 (permalink)
yup, been using those... but like i said, I can get them closer together, but can do anything with the shaft.... should I push it in more or pull all together?
Old 01-07-2013, 09:05 AM   #4 (permalink)
Darth Tater's Avatar
Try pushing down slightly on the shaft (toward the final drive housing), as you compress the c-clip. Once compressed, the c-clip should come out of the groove.
Once the c-clip is out of the groove, the drive shaft should pull straight out.
_____________________________________________
'08 C50T Kuryakyn HyperCharger Intake w/ Stinger Trap Door, American Racing Light Bar, Dobeck Gen 2 FI controller, American Racing slip on mufflers(?), LED mod on Dash Panel, LED Kit, Baron Mini-Tach
Darth Tater is offline   Reply With Quote
The Following User Says Thank You to Darth Tater For This Useful Post:
Hugod (01-07-2013)
Old 01-07-2013, 09:07 AM   #5 (permalink)
thank you much, i'll give it try later today
Old 01-07-2013, 09:41 AM   #6 (permalink)
MoDZuKi's Avatar
Yep The way I take them out is to pull the clip in with the pliers and compress the shaft then it just lifts out- alternately is to pry one side with a screw driver - that kinda wrecks the clip tho. Pushing DOWN on the shaft to make clearance while compressing the clip is the secret tho- its easy once the pressure on it is relieved.
MoDZuKi is offline   Reply With Quote
The Following User Says Thank You to MoDZuKi For This Useful Post:
Hugod (01-07-2013)
Old 01-07-2013, 09:45 AM   #7 (permalink)
Hi-Vis's Avatar
That's what I did M50Dave. I also bought a new set of snap ring pliers. Those multi-angle type. The shoulders that held the pins on that tool were so large I could not get both of the pins hooked on the snap ring. I even took my Makita grinder to the brand new tool.
I just man handled it out.
Be sure to use eye protection.
Special Edition 2009 C50 Green/White . 13100 miles. Loaded up and then some!
ATGATT Sweat, not blood.
Hi-Vis is online now   Reply With Quote
Old 01-07-2013, 12:22 PM   #8 (permalink)
Rich H's Avatar
The first time I tried this project I had a cheap set of snap ring pliers and no matter how hard I tried I could not get that snap ring out. Finely, I went to Sears and bought their best set and it was a breeze.
Rich H
2008 DJ C50T, 2007 C50T sold.
Rich H is offline   Reply With Quote
The Following User Says Thank You to Rich H For This Useful Post:
Hugod (01-07-2013)
Old 01-07-2013, 09:19 PM   #9 (permalink)
Thank you all guys!
I was apparently too focused on the "eyes" of the circlips and never noticed that the back of the ring was already popping out. So, once I realized that....
Thanks everybody!
Safe trails
